juangea
Post by juangea » Wed Jun 02, 2021 9:50 pm
Ok, thanks :)
Post by Dade » Thu Jun 03, 2021 9:42 am
Dade wrote:
Wed Jun 02, 2021 4:13 pm
juangea wrote:
Wed Jun 02, 2021 11:59 am
Are the Linux ones also with 3.9 or not yet?
Not yet.
New Linux builds are now on compatible with Blender v2.93.
Carlosmpa
Post by Carlosmpa » Wed Jun 09, 2021 7:13 pm
I must be doing something wrong on my side because I simply can't get Luxcore add-on to be enabled.
I deleted Blender 2.92, deleted all Luxcore install files. Downloaded Blender 2.93 and the latest BlendLuxCore build Today ( June9th).
I can install the plugin, but every time I try to enable it it shows the following error:
I had 2.5 working with no issues on Blender 2.92 with GPU support but.... well you know, there is a newer version so I upgraded...
I have tried to install the Master and replace the Bin files, did not work, Install the Latest build, will not enable.
I'm on a Mac Pro
OS 11.4 Intel Xeon E5. 64Gb Ram
Dual AMD FirePro D700
Any ideas on How I can get this working again?
Post by Dade » Wed Jun 09, 2021 10:53 pm
Try to check if you have the mentioned missing file (i.e. "libtiff.5.dylib"). I don't have a a Mac but I downloaded the .zip and it looks like the motioned file is there.
Carlosmpa
Post by Carlosmpa » Thu Jun 10, 2021 6:21 pm
Thanks for the reply. I checked the installed folders and both of the files mentioned in the error are in the folder, so I'm not sure why the error says it can't be found.
Carlosmpa
Post by Carlosmpa » Wed Jun 23, 2021 7:25 pm
So I found the solution to this and I thought I'd post in case anyone else runs into this same issue. it was a lot simpler than I thought.
The "scripts" folder was created with Read Only permissions. Once I changed the permissions for admins and system to be Read and Write then Luxcore installed successfully.
I found someone with a similar issue and the solution in this thread.
https://developer.blender.org/T77962
