Are you talking of this (viewtopic.php?f=2&t=207#p2662) answer ?lighting_freak wrote: Tue Apr 10, 2018 7:06 am did I got you right? I shall create the emitting surface inside the volume.
Lit up tests
Re: Lit up tests
lighting_freak
Re: Lit up tests
yes, I was talking about that...
If the light emitting surface is completly surrounded by the same medium it should emit light in a correct way no matter what's the surface normal pointing to.
The glass node could also pick it's refractive index from internal volume like it always does.
The only disadvantage seems to be that you have an additional surface.
Please consider the "flip emitting direction" checkbox anyway.
I'm still thinking that it keeps somewhat a logical base for the stuff we're doing. Thanks.
BR
BR
OS - Windows 7 X64
CPU - Intel CORE i7
CPU - Intel CORE i7
