Faster Compiling kernels
Re: Faster Compiling kernels
Post by Dade » Fri Apr 30, 2021 9:22 am
TAO wrote:
Thu Apr 29, 2021 11:19 pm
What about the minimum requirements to use LuxCore?
It requires CUDA 10 support at least.
Continuum
Post by Continuum » Sat May 01, 2021 3:55 pm
Opencl 3.0 seems to have fixed the issues Nvidia had with it. There are already drivers apparently. I guess someone with Nvidia hardware should confirm this.
https://developer.nvidia.com/blog/nvidi ... onformant/
Personally this is excellent news, Opencl development skills are still very relevant, for the present and future it would seem.
Post by Dade » Sat May 01, 2021 5:07 pm
Where do you read it ? I bet the compilation will be as slow as usual, CUDA is slow too. OpenCL v3.0 is the biggest joke ever made: it is just OpenCL v1.2 under a different name.
Post by TAO » Sat May 01, 2021 5:08 pm
Yes, exactly that was the reason i reported they release the new version of OpenCL and that was a piece of good news because, Nvidia out of nowhere decide to add it in new driver packs, exactly the day when we started this conversation. I'm pretty sure there is a good reason behind that and i think Nvidia does not want to get involved in a GPU fight with AMD at the moment especially after what happens to the Intel share market with AMD and Apple new chip otherwise there is no reason at all why they decide to support OpenCL after all these years and in just 2 days.
I personally have a good feeling about that.
Latest build Download link👇👇
https://forums.luxcorerender.org/viewto ... 560#p29626
Post by TAO » Sat May 01, 2021 5:13 pm
With the recently released R465 display driver, NVIDIA is now officially OpenCL 3.0 conformant on both Windows and Linux.
Post by TAO » Sat May 01, 2021 5:34 pm
I already install and test it. it is really OpenCL 3.
I check every part of it, not just the file version and the result is the same.
Continuum
Post by Continuum » Sat May 01, 2021 6:18 pm
It wasn't a performance issue that was preventing Opencl adoption I think. I can't find the reference now, but Opencl 2.0 introduced features which would have affected Nvidia drivers negatively. Opencl 3.0 changed that I believe.
I don't know about compilation, the issue can always be shared with the developers. If Vulkan & Opencl become compatible, then precompiled code may be possible (spir).
From what I can see Nvidia supports quite a few technologies that they do not own. They have a fluids simulation engine written in Direct X, it's quite good.
Post by Dade » Sat May 01, 2021 6:41 pm
You are talking of OpenCL v3.0 like if it is something new: it isn't, it is OpenCL v1.2. Plain nothing has changed. Still everything stuck to OpenCL v1.2 (now known as v3.0).
Post by TAO » Sat May 01, 2021 7:10 pm
Honestly, you know OpenCL better than anyone and it is sad to see nothing change in it.
At least we can leave it as it is or just update to the new version for now.
Continuum
Post by Continuum » Sat May 01, 2021 7:11 pm
Not completely true, if you go through the driver release notes, it's show features beyond v1.2 have been included, including experimental features from v2.0. Link below.
https://us.download.nvidia.com/Windows/ ... -notes.pdf
