To be more specific:
I have a large Background plane that I want to appear as background (in render) not affecting anything but camera.
Right now I can disable shadows and use emission on the plane, I can also disable "use photonGI cache".
However this will still generate pgi entries and since it is a large object far away I will end up with very few entries inside my environment. That also causes poor pgi quality and performance.
no background only simple lighting
with background that is supposed to be backplae
this option doesn't affect the issue in any way
Another use case I often end up with is lights that should appear as lights but I don't want to use them as lightsources.
For example I was working on a colored rough stained glass lamp that needed to be presented in interior, but as you can see, trying to use that object as actual light source would totally kill rendering performance. In cycles/other renderers you can disable diffuse lighting visibility and use simple fake light as an actual emittor.
So this is not only affecting pgi quality in many cases but in general there are a LOT of cases where you don't really want to use emission as an actual emission cause of performance issues.
EDIT:
I just noticed, it happens even without emission, so just having a large plane far away will ruin the pgi quality and performance. Anyways, a complete exclusion except camera rays might still solve this...?
emission ruins photon cache
Re: emission ruins photon cache
If you disable material direct light sampling, it should not affect performance at alllacilaci wrote: Thu Apr 29, 2021 10:30 am For example I was working on a colored rough stained glass lamp that needed to be presented in interior, but as you can see, trying to use that object as actual light source would totally kill rendering performance.
I will be back to the first topic later.
I don't understand why you don't use transparent background and compose the image using alphalacilaci wrote: Thu Apr 29, 2021 10:30 am To be more specific:
The far plane can have a large impact on the heuristic to determinate the radius used for PGI. You can set the radius by hand to try to work around the problem.lacilaci wrote: Thu Apr 29, 2021 10:30 am EDIT:
It is something I have written in the past: the source of the problem is having a constant radius for PGI, this cause some problem when you have very near and very far objects.
However, using transparent film would solve this problem too.
It is a common way of doing thing without extra steps directly inside the 3D package. It easy efficient and fast.I don't understand why you don't use transparent background and compose the image using alpha
BTW i've tested it and don't have issue while disable PGI on the backplate and set back opacity to zero.so i can use an hdri or sky for lighting
With Bckplate
Without Bckplate
Ok I see I have mentioned affecting camera only, but I want matching reflections too. This would need to happen in-render. For camera only I could composite in post, sure.Dade wrote: Thu Apr 29, 2021 11:11 amI don't understand why you don't use transparent background and compose the image using alphalacilaci wrote: Thu Apr 29, 2021 10:30 am To be more specific:
I have a large Background plane that I want to appear as background (in render) not affecting anything but camera.![]()
Yes I am actually using fixed radius, doesn't help. Maybe if I used some insane number of Photon Count...Dade wrote: Thu Apr 29, 2021 11:11 am
It looks like you used very small backplate. Mine is much bigger than the whole scene (this is sometimes necessary for proper paralax camera movement and reflections, and of course if your scene is big)Sharlybg wrote: Thu Apr 29, 2021 11:29 amIt is a common way of doing thing without extra steps directly inside the 3D package. It easy efficient and fast.I don't understand why you don't use transparent background and compose the image using alpha
With Bckplate
Without Bckplate
Yes you are right i made bckplate 10X bigger and it kill all.It looks like you used very small backplate. Mine is much bigger than the whole scene (this is sometimes necessary for proper paralax camera movement and reflections, and of course if your scene is big)
Another idea is just to compute cache without BCKPLTE and then reuse this precomputed cache for the large bckplte version. Wouldn't that work ?
EDIT
IT work
how is this handled with environent/hdri light?Dade wrote: Thu Apr 29, 2021 11:11 am the source of the problem is having a constant radius for PGI, this cause some problem when you have very near and very far objects.
Annoying workaround, but this works!Sharlybg wrote: Thu Apr 29, 2021 12:13 pmYes you are right i made bckplate 10X bigger and it kill all.It looks like you used very small backplate. Mine is much bigger than the whole scene (this is sometimes necessary for proper paralax camera movement and reflections, and of course if your scene is big)
EDIT
IT work![]()
I still hope to have this feature at some point.
