dark gradients
dark gradients
Post by lacilaci »
I don't know for sure, but this doesnt look normal to me.
roughness at 1
roughness at 0.8
file
shd_error_lux.blend
(3.01 MiB) Downloaded 279 times
What I don't understand is the dark gradient near corners, it only appears with medium-high roughness and it makes walls appear floating.
in cycles's principled shader the behavior is consistent without weird dark corners.
Is this normal?
Re: dark gradients
It remenber me the grazing angle darkening issue. And i think we do need a new Shading model (Luxcore 3.0 maybe ) for that to be solved.
Re: dark gradients
Post by lacilaci »
Sharlybg wrote: Wed Apr 28, 2021 12:13 pm It remenber me the grazing angle darkening issue. And i think we do need a new Shading model (Luxcore 3.0 maybe ) for that to be solved.
I know this is an issue with older shaders (matte, glossy...) I thought disney doesn't show the problem (it doesn't in cycles at least)
I think bidir in luxcore also works well but haven't tested
