Brazilian Liquor
JulianoLisboa
Re: Brazilian Liquor
Post by JulianoLisboa »
Sharlybg wrote: Thu Apr 22, 2021 7:46 am
JulianoLisboa wrote: Thu Apr 22, 2021 12:21 am
Sharlybg wrote: Wed Apr 21, 2021 6:56 pm A lot better. ;)
Can I see the shader node of both the glass cup and bottles ?
Can you also check normal orientation on the glass cup ?
Do you have shadow color applied at maximum white value on the glass cup ?
Hello, follow the link to download the file.
https://drive.google.com/file/d/1V1I3he ... sp=sharing
Acces denied ;)
Sorry.
Much better, now it's great.
JulianoLisboa
Thank you, but I am waiting for Sharlybg's comments, so I think it will get even better. He must have downloaded the file.
JulianoLisboa wrote: Fri Apr 23, 2021 7:44 pm Thank you, but I am waiting for Sharlybg's comments, so I think it will get even better. He must have downloaded the file.
Just have few minute to investigate the file a bit :
1__ You should work at real world scale with Luxcore to avoid starnge behaviour. Your bottle is 6Meter high here
2__ There is not to much challenging thing in the scene ( not like here : https://youtu.be/R2-u3YNJbHQ ) so Shadow color to white is a bit overkill almost switch off all nice caustic. So default for all is good here.
3__ The liquid mesh inside the bottle have normal inverted.
4__ You can imrove lighting by smoothing plane light edge like in this tutorial for a more natural blending look :
https://youtu.be/32Ojuidbc7k?t=155
Hope it help a bit.
JulianoLisboa
Thank you my friend .... I will follow your directions
JulianoLisboa
Thanks to everyone who helped me, follow the final image.
Couldn'd imagine it will look like that at the end well done.
AndreasResch
Post by AndreasResch »
Much better than the initial version - especially the poured glass. One little thing. The label looks a bit dark now (especially the lower part). Maybe adding a little frontal/side light back in can fix that. Not as much as in the original version though.
JulianoLisboa
AndreasResch wrote: Sat Apr 24, 2021 7:41 am Much better than the initial version - especially the poured glass. One little thing. The label looks a bit dark now (especially the lower part). Maybe adding a little frontal/side light back in can fix that. Not as much as in the original version though.
Thank you friend, yes the observation proceeds, every time I look I think that the image is finished I find something to fix. About the label I wanted to look more dramatic, but it really got darker than necessary.
Great job.
