Brazilian Liquor
JulianoLisboa
Brazilian Liquor
Post by JulianoLisboa »
Illustration work done at Luxcore, for me every day is a different learning experience, but I'm happy with the result. Criticisms and suggestions are welcome.
Re: Brazilian Liquor
Vola, nicely done, I enjoy the look. just there is a little bit too much glossiness on the wood, I think with less glossy it will be much realistic.
Dez!
Post by Dez! »
excellent work but needs some work.
yes, the gloss is controversial. and somewhere it looks good, but for the most part it needs to be muted.
I recommend finalizing the image in a photo editor, and manually reducing the gloss in some places.
I also propose to manually add in this place the feeling of contact between the glass and the barrel:
https://i.imgur.com/NyhzVZ3.png
Nice looking project it is also interesting that you have been able to render at a good resolution too.it certainly well done in general.
Few advice i will give even if your work is already good (just in case you want more ):
1_ liquid and container must overlap and have different priority value (container highe priority compare to liquid ) otherwise you end up with liquid floating inside the glass.
2_I also think that glass quality should go up as the render is mostly about that (Specular value between 24 and 64 can reveal some nice internal reflection)
3_ The render need more samples to avoid to much blur. (work at lower resolution and do your absolute result in higher format)
4_ Good thing can be to use nice reference for lighting and and glass quality as well as caustics.
ddcbf6a0ca75b3c943aee60623063b14af307903dd044b2ef46bdefd4c5466ae93f48423d3771eeb_rw_1200.jpg
Sharlybg wrote: Wed Apr 21, 2021 7:39 am
That's a piece of good advice for me too, i did not know that. Thanks, dude.
JulianoLisboa
What is the difference between the volume created in the luxcore material nodes and the volume created in the luxcore volume nodes?
JulianoLisboa
Sharlybg wrote: Wed Apr 21, 2021 7:39 am Nice looking project it is also interesting that you have been able to render at a good resolution too.it certainly well done in general.
Thanks for the tips, I tried here and got this result.
A lot better. ;)
Can I see the shader node of both the glass cup and bottles ?
Can you also check normal orientation on the glass cup ?
Do you have shadow color applied at maximum white value on the glass cup ?
JulianoLisboa
Sharlybg wrote: Wed Apr 21, 2021 6:56 pm A lot better. ;)
Hello, follow the link to download the file.
https://drive.google.com/file/d/1V1I3he ... sp=sharing
JulianoLisboa wrote: Thu Apr 22, 2021 12:21 am
Acces denied ;)
