At v2.5 - if GPU contains RTX - is RTX\Optix automatically enabled in CUDA rendering? Because I can't see any checkbox today. (I read about changes, there is a note about force disabling Optix even if card support it)
The BlendLuxCore daily builds are now working again.
@B.Y.O.B. I have bumped the version number in BlendLuxCore to re-enable daily builds.
We were in a corner case for which I have no good solution yet: when the BlendLuxCore pipeline is triggered by a LuxCore daily build, and the latest BlendLuxCore commit is tagged for another release, no BlendLuxCore daily release is generated.
I'll try to fix this before next official release (I'm not sure if it's possible, however).
Yes, it is enabled for all RTX GPUs and disabled on others (for instance GTX1080) because it is slower than our code in our tests.
Thanks.acasta69 wrote: Wed Apr 21, 2021 6:42 am @B.Y.O.B. I have bumped the version number in BlendLuxCore to re-enable daily builds.
Not sure if this is worth fixing, having to bump the version is not really a problem in my opinion.
Somehow I cannot install the latest BlendLuxCore 2.6 alpha on Windows (screenshot below) or MacOS with Blender 2.92. I have not Installed VS2019 because I saw it was reverted to VS2017.
Hi, I have the same as @epilectrolytics on Windows 10 and a different error on Linux.
Cheers, mib
Making LuxCore denoiser executable
File "/home/pepo/blender-2.92.0-linux64/2.92/scripts/modules/addon_utils.py", line 351, in enable
mod = __import__(module_name)
File "/home/pepo/.config/blender/2.92/scripts/addons/BlendLuxCore/__init__.py", line 63, in <module>
Exception:
Could not import pyluxcore.
ImportError: libOpenImageDenoise.so.1: cannot open shared object file: No such file or directory
I also can't install it on 2.83
I should have fixed this, some change was required because of upgraded libraries.
A new build should be ready in minutes.
I hope it works also on Linux, I have no way to check.
About MacOS I'm not able to help, sorry, but it's probably a different problem.
Now the Windows version works, thanks @acasta69 for the fix!
(MacOS 10.13 still defaults with error shown below:)
Thank you very much, your fix is working on Linux!acasta69 wrote: Wed Apr 21, 2021 2:07 pm I should have fixed this, some change was required because of upgraded libraries.
Cheers, mib
