Oh... Well i don't know much about science behind, but from what i've gathered from the quick look, it seems to be something about data in cubic form (i've also stumbled on cases used for chemical, atomic structures). In case of LUTs i think it's about 3d color space transformations (3 curves RGB/XYZ) using similar or same rules. But really IDK.Dade wrote: Sat Mar 31, 2018 8:22 pmI think it is related, it is just quite strange to use a volumetric format for a camera response.kintuX wrote: Sat Mar 31, 2018 8:07 pmOh, my bad, that's unrelated. Sorry to waste your time.Dade wrote: Sat Mar 31, 2018 10:43 am
It seems to talk about volumetric data: http://paulbourke.net/dataformats/cube/
How is this related to camera response![]()
BlendLuxCore Development
Re: BlendLuxCore Development
BlendLuxCore now contains an option to automatically calculate the best step size and max. steps for smoke simulations:
Nice one, you keep surprisingB.Y.O.B. wrote: Sat Mar 31, 2018 9:58 pm BlendLuxCore now contains an option to automatically calculate the best step size and max. steps for smoke simulations:
One other thing i've been wanting to ask about BiDir settings.
Since by using BiDir engine, there's no clamping option available and fireflies are quite problematic to resolve, is it possible to have SuperSampling exposed (assuming that it hasn't been removed)?
The addon now shows an error message if the old LuxBlend addon was enabled and explains the next steps you have to take to make everything work.
Unfortunately I can't hide the traceback on top.
The min. epsilon setting is now exposed (should be used only by advanced users or when a developer tells you to change it due to a bug report).
Hi B.Y.O.B., testing the new LuxCore and got it to work until I download BlendLuxCore again and delete the "old" one.
I get error enable addon now:
I´ed be happy for help, mib
Btw. Congratulations for the new BlendLuxCore and LuxCore2.
read prefs: /home/pepo/.config/blender/2.79/config/userpref.blend
found bundled python: /home/pepo/blender-2.79a-linux-glibc219-x86_64/2.79/python
path not found
path not found
search for unknown operator 'SCULPT_OT_silhouette_draw', 'SCULPT_OT_silhouette_draw'
File "/home/pepo/blender-2.79a-linux-glibc219-x86_64/2.79/scripts/modules/addon_utils.py", line 331, in enable
mod = __import__(module_name)
File "/home/pepo/blender-2.79a-linux-glibc219-x86_64/2.79/scripts/addons/BlendLuxCore/__init__.py", line 2, in <module>
from .bin import pyluxcore
ImportError: /home/pepo/blender-2.79a-linux-glibc219-x86_64/2.79/scripts/addons/BlendLuxCore/bin/libembree.so.2: undefined symbol: _ZN3tbb10interface78internal15task_arena_base24internal_max_concurrencyEPKNS0_10task_arenaE
Do you have an old LuxBlend installation? Disable it in the user prefs, save user prefs, restart and try again.
By the way 2.79b is out (but it does not matter for this problem).
Hi, I don´t had an old Luxblend installed.
Tested again with Blender 2.79b but same error. :/
No idea how I got it to work before.
Cheers, mib
Cheers, mib
Check /home/pepo/blender-2.79a-linux-glibc219-x86_64/2.79/scripts/addons/BlendLuxCore/bin, post here the content, does it includes:mib2berlin wrote: Mon Apr 09, 2018 7:15 am Hi, I don´t had an old Luxblend installed.
-rw-rw-r-- 1 david david 782121 Apr 5 21:12 libtbbmalloc.so.2
-rw-rw-r-- 1 david david 2051877 Apr 5 21:12 libtbb.so.2
-rwxr-xr-x 1 pepo users 2112 4. Apr 11:40 get_binaries.py
-rw-r--r-- 1 pepo users 0 4. Apr 11:40 __init__.py
-rwxr-xr-x 1 pepo users 37081857 4. Apr 10:37 libembree.so.2
-rwxr-xr-x 1 pepo users 782121 4. Apr 10:37 libtbbmalloc.so.2
-rwxr-xr-x 1 pepo users 2051877 4. Apr 10:37 libtbb.so.2
drwxr-xr-x 2 pepo users 37 9. Apr 09:07 __pycache__
-rwxr-xr-x 1 pepo users 30430879 4. Apr 10:37 pyluxcore.so
-rw-r--r-- 1 pepo users 671 4. Apr 11:40 readme.md
Jens PM´ed me to help at #blendercoders, he has a fix as he told me.
Cheers, mib
