[SOLVED] Hair material
Leandro Oliveira
Post by Leandro Oliveira »
Hi guys!
I´m trying to make "fur" for a rug. In Cycles, it´s possible to use the material of the emitter, in the hair. I noted that this is possible in Lux, too, but hair keep rendering in black color. How can I fix it?
I´m using Lux 2.5 Beta1
Last edited by Leandro Oliveira on Fri Dec 11, 2020 12:06 pm, edited 1 time in total.
Re: Hair material
Please read and follow the forum rules in the red box above.
Leandro Oliveira
Re: Hair material
Sorry. Here´s the file.
testRug.blend
(2 MiB) Downloaded 266 times
Thanks.
DionXein
Re: Hair material
Post by DionXein »
Leandro Oliveira wrote: Thu Dec 10, 2020 12:53 pm I´m trying to make "fur" for a rug. In Cycles, it´s possible to use the material of the emitter, in the hair. I noted that this is possible in Lux, too, but hair keep rendering in black color. How can I fix it?
Man, it's all onto bump. Also in Cycles usually used second material, like Principle Hair (it's optimised for strands rendering). So If you want your carpet using bump create separate material for particle system.
Leandro Oliveira
Re: Hair material
@DionXein, thank you, man! :)
