continuous crashes while rendering
em3d
Post by em3d »
Hi im experimenting a lot of CUDA API "Crashes" with a very simple room scene...
sudenly it give me an Out of memory error, or render session stay blocked exporting some mesh
the scene work, and it was rendered a few times
but when i made some little changes (linking a material)
i can not rendered any more and i spend a lot of time getting those errors....
my config i6800hk + gtx1070 8G + 64gb ram
latest lux buid + 2.91 official
thanks for your help
console.zip
(7.95 KiB) Downloaded 280 times
em3d
Re: continuous crashes while rendering
Post by em3d »
maybe its a linked material whats its giving the errors
i check material overide and render works,
then i uncked the overide , its start rendering again
i had a lots of materials linked due to pc limitations at office
[LuxRays][2352.672] Total vertex count: 69449358
[LuxRays][2352.672] Total triangle count: 124565410
RuntimeError: CUDA driver API error CUDA_ERROR_OUT_OF_MEMORY (code: 2, file:D:\a\1\Luxcore\src\luxrays\devices\cudadevice.cpp, line: 516): out of memory
You are simply running out of GPU ram while trying to render 124,565,410 triangles (!).
124 millions of triangles doesn't sound exactly like a very simple room scene :?:
Do you have some "out of control" subdivision, etc. ?
