Hi (So excited about this new version. Big thanks!)
I'm getting an error message when trying to activate in Blender 2.79b (attached)
Any help please.
Thanks again
Installation problem
Re: Installation problem
Can you check if a "pyluxcore.pyd" file exists in your "Blender/2.79/scripts/addons/BlendLuxCore-master/bin" directory ?Racleborg wrote: Sat Apr 07, 2018 10:36 am I'm getting an error message when trying to activate in Blender 2.79b (attached)
Any help please.
Hi Dade
Thanks for responding
No, it's not there.
No, it's not there.
Something has gone wrong during the installation. Did you installed .zip as described here (https://wiki.luxcorerender.org/BlendLux ... stallation) ?
The "-master" suffix in the name of the "BlendLuxCore-master" directory is a bit strange, are you trying to install BlendLuxCore from GitHub sources ?
Anyway, deleting the Blender/2.79/scripts/addons/BlendLuxCore-master" directory and following the https://wiki.luxcorerender.org/BlendLux ... stallation should be enough to solve your problem.
You can't simply download from github. You need to download a release from the release section or go to the download page on luxcorerender.org and get it from there.
Hi Dade
Yes, tried to install from github. Whilst doing it I uninstalled the original programme and probably screwed something up in the process!
I'll use your suggestion (in a few minutes) and report back.
Thanks
Thanks
That's it, downloading the beta from the proper download page instead of from Github
Thanks for helping me out.
Have a nice weekend. I know what I'll be doing with mine......!
On the same issue:
I have installed Blender 2.79 and BlendLuxCore on a new PC with Win10.
There was no problem to activate LuxCore after install.
But when I try to load a Blender scene and then activate LuxCore, I get the following error msg:
pyluxcore.pyd seems on its place, in:
C:\Users\igall\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\bin
What could go wrong?
Many thanks,
Igal
On the same issue:
Many thanks,
Igal
If you are using OpenCL version on a PC where OpenCL version is not available or other various related problems: you can find here (https://github.com/LuxCoreRender/BlendL ... issues/138) a long discussion about this problem an the possible causes. You can just follow my suggestions there to debug what is going wrong.igall wrote: Thu Apr 26, 2018 2:28 pm On the same issue:
Error Ubuntu: libOpenCL.so.1
Enter:
Enter:
sudo apt update
sudo apt install ocl-icd-opencl-devLinux Plasma | Ryzen 5, 32Gb, SSD M2, GT 590 RX | BenQ 27 | Wacom One | Microsoft Ergo | Tie Guan Yin tea
