Very long wait for caches enabled
nigma46
Post by nigma46 »
I am a new blendluxcore user and a new Blender user.
I am finding luxcore to be superior to regular cycles when rendering my scene, which is the Roman Pantheon. A challenging scene to light due to the singular circlular opening in the roof, the oculus. I prefer to light with a single HDRI, to get the most realistic lighting.
However, the issue I am having is that when attempting to use caches, photogi indirect and/or environment cache, i have to wait 20-30mins before the render starts, if it starts at all. Is this because of my complexe scene (>100 MTris)? I'd prefer to use the caches, since when it works I see the speed improvement.
Running Blender v2.90, Win10 64bit, nVidia drivers: 452.06
i7 3770k /w 24GB ram, 980 GTX
Image0028_pregamma_1_durand_spatial_90_range_7.5_base_4.8_postsaturation_1_postgamma_1.jpg
nigma46
Re: Very long wait for caches enabled
Post by nigma46 »
Update:
I had been using luxcore 2.4 with Blender 2.9. But I just tried the daily release of luxcore 2.5 and with environment light cache only enabled it completed in 2.5 minutes, instead of the 10 minutes with luxcore 2.4, excellent! If I enable photongi it doesn't complete even after 50 mins. =/
nigma46 wrote: Fri Nov 06, 2020 9:36 am Update:
can you show the concerned Cache setting you have ?
nigma46
Post by nigma46 »
Sharlybg: Sure, see attached. I've tried photongi with default settings. It is currently turned off in the screenshot, but i was using default settings.
Reduce your photon count to 2 million instead of current 20 millions.
reduce your brute force radius scale to 1 instead of 8 and try render again.
Brute force radius scale has no influence on the cache building time, it only influences rendering performance after the cache is built.
@OP:
Can you provide a stripped-down simplified testscene that still shows the problem? Try removing textures, replacing high-poly objects with simplified meshes, etc.
Please also mention what kind of hardware you are rendering on.
Another good thing to have would be a log output from the console.
nigma46
Post by nigma46 »
B.Y.O.B. wrote: Fri Nov 06, 2020 11:30 am Brute force radius scale has no influence on the cache building time, it only influences rendering performance after the cache is built.
@OP:
thanks for youre reply. I am rendering with GPU only, a 980gtx card.
I dont have any textures except for blueprints on large planes, these are hidden from rendering in cycles, it seems this setting also applied for luxcore. I could try remove these planes from the scene as a test.
I dont have an easy way to reduce the poly count in my scene other than use the simplify option that exists in cycles, though I have been working if luxcore can read this setting, can it? I think it might as I think I remember setting it to 0 subdivision surfaces for render and thought i noticed reduced polys in luxcore.
nigma46
Post by nigma46 »
Sharlybg wrote: Fri Nov 06, 2020 11:26 am Reduce your photon count to 2 million instead of current 20 millions.
I think I did try reduce photon count, but got light leaks and pre-render calc time didn't seem to decrease much.
yes i know that. i want affect both build time and rendering perf.
nigma46
Post by nigma46 »
I tried to exclude the blueprint "emptys" from luxcore render and set PhotonGI photon number to 1 million. Still did not finish pre-calcs for 15 mins, then I cancelled.
