Rendering
Re: Rendering
Skilled420 wrote: Wed Nov 04, 2020 4:12 pm How would I create something that looks like this:Image
BTW with luxcore it is a good thing to work at object real world scale. It is going to save you lot of headaches :mrgreen:
Skilled420
Re: Rendering
Post by Skilled420 »
Why would be better?
Re: Rendering
I would try a mix with rough glass, maybe driven by a texture for the mix amount.
Sharlybg wrote: Thu Nov 05, 2020 11:55 am BTW with luxcore it is a good thing to work at object real world scale. It is going to save you lot of headaches
Skilled420 wrote: Thu Nov 05, 2020 5:38 pm Why would be better?
This is a good idea most of the time, not only with LuxCore. It ensures correct light falloff behaviour, makes it easier to re-use assets in different scenes, and makes adjusting stuff like bump height or photon radius less of a trial-and-error process.
I rendered your scene with path + light tracing + caustics cache by the way, which is able to show SDS paths like the caustics mirrored in the side of the glass:
Cup4.blend
(1.78 MiB) Downloaded 234 times
