Nk metal profile
Nk metal profile
Do anyone know where i can download some nk metal profike to use with luxcore shader ?
Re: Nk metal profile
There seem to be some lists here:
https://github.com/ulfgri/nk/tree/master/sopra (sopra files)
http://luxpop.com/RefractiveIndexList.html (Luxpop files)
Dez!
Post by Dez! »
i tried several.
some did not allow the render to start.
others look like nothing black.
yeah I've just tried, too.
The sopra files return "bad header", and the luxpop are just black...
EDIT: This post was wrong
I found nk data included with Maxwell & Indigo working fine.
Dez!
Post by Dez! »
show what happens?
I tried removing the code below, but only black on the render.
Dez! wrote: Fri Oct 30, 2020 11:59 am show what happens?
Same here .
Actually I was wrong there (bad choice of data files)
Upon resinpection I found another problem: For example the CoO.nk file does not go into the visible spectral range, it only has UV and below, so LuxCore doesn't have data to work with.
