TwoSided material
Re: TwoSided material
B.Y.O.B. wrote: Thu Sep 17, 2020 9:55 am The glossy material has a weird legacy behaviour, see https://github.com/LuxCoreRender/LuxCore/issues/301
Yes, it may be better to use Disney material.
CEROE
Post by CEROE »
Of course, the problem is that we lose translucency by using the Disney material.
Also, what is the technique for including the quotes in your responses?
CEROE
Post by CEROE »
Probably like this.
CEROE wrote: Thu Sep 17, 2020 4:48 pm Of course, the problem is that we lose translucency by using the Disney material.
You could use generic material transparency. But where you using Glossy material or something like GlossyTranslucent ?
Does the twosided material work with glossytranslucent?
CEROE
Post by CEROE »
Glossy Translucent is the material I am testing. Mixing two Glossy Translucent materials with the Two Sided node.
Do you have an idea why the faces would switch when mirroring an object?
CEROE wrote: Thu Sep 17, 2020 9:07 pm Glossy Translucent is the material I am testing. Mixing two Glossy Translucent materials with the Two Sided node.
TwoSided + 2 x GlossyTranslucent = GlossyTranslucent
Both produce the same rendering because the asymmetric nature of GlossyTranslucent material (different behaviors if you are going into the object or getting out of the object) .
The simple solution could be to add a "flip option" to GlossyTranslucent.
Dade wrote: Thu Sep 17, 2020 11:13 pm The simple solution could be to add a "flip option" to GlossyTranslucent.
I can probably extend the concept and have a "flip option" for all asymmetric Lux materials.
CEROE
Post by CEROE »
Is there anything ready to test for this?
CEROE wrote: Sun Sep 20, 2020 5:38 pm
I haven't yet written the code.
