I wonder how you manage to create crf file. But now .cube file are the most common ( see corona and Fstorm).B.Y.O.B. wrote: Fri Mar 30, 2018 8:09 pm Sorry, I completely forgot you can already use a custom file.
I will add the plugin.
BlendLuxCore Development
Re: BlendLuxCore Development
If some has the specs of .cube file format, it may be possible to add the support
Thank you.B.Y.O.B. wrote: Fri Mar 30, 2018 8:09 pm Sorry, I completely forgot you can already use a custom file.
Do you mean something like the Gaussian CUBE File Format (by GODOT Engine @ GitHub) or...?Dade wrote: Fri Mar 30, 2018 10:37 pm If some has the specs of .cube file format, it may be possible to add the support![]()
It seems to talk about volumetric data: http://paulbourke.net/dataformats/cube/kintuX wrote: Fri Mar 30, 2018 11:02 pmDo you mean something like the Gaussian CUBE File Format (by GODOT Engine @ GitHub) or...?Dade wrote: Fri Mar 30, 2018 10:37 pm If some has the specs of .cube file format, it may be possible to add the support![]()
How is this related to camera response
- Odilkhan Yakubov
Why did you removed other integrators from the core? I like the Photon Mapping. Especially, it can be best integrator for CPU rendering. Is it possible to comeback that integrator again? I'm very pleased. Thanks.
For specification i think this link is more close to the subject :
https://github.com/wilg/LUTSpec
See here it's these type of files :
A video to see how their are made :Note:
All of the Gorilla Grade LUTs are 3D LUTs in .cube, .3DL, and .look formats and are sRGB Look LUTs. They are not created to work in LOG.
https://www.youtube.com/watch?v=3tyYjsY ... e=youtu.be
The link to the specs is broken but this seems to work: http://archive.is/cWkgiSharlybg wrote: Sat Mar 31, 2018 12:44 pmIt seems to talk about volumetric data: http://paulbourke.net/dataformats/cube/
P.S. https://github.com/LuxCoreRender/LuxCore/issues/81
Oh, my bad, that's unrelated. Sorry to waste your time.Dade wrote: Sat Mar 31, 2018 10:43 amIt seems to talk about volumetric data: http://paulbourke.net/dataformats/cube/kintuX wrote: Fri Mar 30, 2018 11:02 pmDo you mean something like the Gaussian CUBE File Format (by GODOT Engine @ GitHub) or...?Dade wrote: Fri Mar 30, 2018 10:37 pm If some has the specs of .cube file format, it may be possible to add the support![]()
How is this related to camera response![]()
I think it is related, it is just quite strange to use a volumetric format for a camera response.kintuX wrote: Sat Mar 31, 2018 8:07 pmOh, my bad, that's unrelated. Sorry to waste your time.Dade wrote: Sat Mar 31, 2018 10:43 amIt seems to talk about volumetric data: http://paulbourke.net/dataformats/cube/kintuX wrote: Fri Mar 30, 2018 11:02 pm
