Metal Material
Re: Metal Material
david57 wrote: Thu May 17, 2018 7:59 pm Here is one I can use.
I found one for brass:
http://www.luxrender.net/forum/viewtopi ... 4&start=10
Yeah, further on also an oxidized version.
And there is still The "Frankenstein" project with whole working nkdata.zip set available.
david57
Re: Metal Material
Post by david57 »
Oh, thats nice, more nk files.
I managed to make my own nickle file from the snell collections.
It can be used as a stainless steel material.
Nickel ni.nk.zip
(481 Bytes) Downloaded 1505 times
Re: Metal Material
B.Y.O.B. wrote: Thu May 17, 2018 8:10 am I can reproduce the problem.
I have investigated the problem and the LuxCore behavior is correct, the file includes numbers like "137756." and they are not valid floating point numbers. However the problem is easy to fix by editing the file and adding a 0 at the end of the malformed number.
HoppyHopp
Re: Metal Material
Post by HoppyHopp »
Hey,
i wanted to know why there is no IOR setting for the Metal Material.
I mean Chromium is about 2.97 and Aluminum 1.44.
Re: Metal Material
For metals, the IOR needs to be described as a complex number - composed of refractive index as the real part and the extinction coefficient as the imaginary part. Furthermore, these two vlaues vary much more over the visible range as in the case of glass, so approximating a single value would not be as good.
I'm not even sure you could make a good convenience-model that uses IOR as a single parameter because of this variation.
Re: Metal Material
It is possible in LuxCore to specify n,k numbers for metal directly, but this is not exposed in BlendLuxCore. It might actually be a good idea to do it, because even with wrong values, you can achieve interesting effects.
HoppyHopp
Re: Metal Material
Post by HoppyHopp »
Would be great!
Artistus
Re: Metal Material
Post by Artistus »
B.Y.O.B. wrote: Fri Sep 04, 2020 12:28 pm It is possible in LuxCore to specify n,k numbers for metal directly, but this is not exposed in BlendLuxCore. It might actually be a good idea to do it, because even with wrong values, you can achieve interesting effects.
Hello!
Is there any way to make some custom node combo to be able to fill Nd and K numbers directly?
Re: Metal Material
I added a "Custom n, k Values" mode to the fresnel texture:
Artistus
Re: Metal Material
Post by Artistus »
B.Y.O.B. wrote: Sat Feb 06, 2021 2:22 pm I added a "Custom n, k Values" mode to the fresnel texture:
Sorry, I'm relatively new to LuxCore.
Actually switching from Maya + Maxwell Render to Blender + BlendLuxCore.
So far I miss maxwell's separate Nd and K fields for custom numbers.
But here you showed that it can handle colors. Wow, it's looking really interesting - something similar to Maxwell's R2 feature.
But you told above that custom numbers are not exposed in BlendLuxCore. Any chance to have them exposed in Blender any soon, maybe at least in some beta version? Or do you mean you have added those custom numbers already to latest beta?
