Here's the Node error:
[Thread-5][2020-08-28 12:51:35,587] [SDL][57438.093] Texture definition: 2937060048344Color
[Thread-5][2020-08-28 12:51:35,587] [SDL][57438.093] Volume definition: 2933295757544
[Thread-5][2020-08-28 12:51:35,588] bad lexical cast: source type value could not be interpreted as target
File "C:\Users\xxxx\AppData\Local\Temp\_MEI230882\pyluxcoretools.zip\pyluxcoretools\renderfarm\renderfarmnode.py", line 168, in __HandleConnection
config = pyluxcore.RenderConfig(renderConfigFile)
RuntimeError: bad lexical cast: source type value could not be interpreted as target
[Thread-5][2020-08-28 12:51:35,645] Connection done: ('192.168.200.46', 61519)
[RenderFarmNodeThread-192.168.200.194:18018][2020-08-28 12:51:50,645] Sending seed: 5
[RenderFarmNodeThread-192.168.200.194:18018][2020-08-28 12:51:50,646] Waiting for node rendering start
[RenderFarmNodeThread-192.168.200.218:18018][2020-08-28 12:51:56,924] Unable to receive a line
File "C:\Users\xxxx\AppData\Local\Temp\_MEI189762\pyluxcoretools.zip\pyluxcoretools\renderfarm\renderfarmjobsingleimage.py", line 423, in NodeThread
result = socketutils.RecvLine(nodeSocket)
File "C:\Users\xxxx\AppData\Local\Temp\_MEI189762\pyluxcoretools.zip\pyluxcoretools\utils\socket.py", line 44, in RecvLine
raise RuntimeError("Unable to receive a line")
RuntimeError: Unable to receive a line
[RenderFarmNodeThread-192.168.200.218:18018][2020-08-28 12:51:56,928] Node thread done
- UV image-mapped glossy texture on default cube.
- HDRI world light instead of a lamp to light the scene.
- Transparent default air volume
- BiDir engine with Metropolis sampler
- Camera tonemapping set to Camera Settings
- 16bit 4k image output size
