sun linked to sky proplem
I'm doing an animation of the transition from sunny to rainy days, but I find that the sun of luxcore has no way to turn off the shadows, which is quite counterproductive. I set the sun's intensity to 0, but since sun is linked to sky, sky's brightness is also set to 0. If sun is not linked to sky, there is no sunrise or sunset effect.Can someone give me some guidance on what I should do?
Re: sun linked to sky proplem
I think I found a solution? I disable the “use sun gain” option in the sky.BruceXu wrote: Fri Aug 21, 2020 3:22 am I'm doing an animation of the transition from sunny to rainy days, but I find that the sun of luxcore has no way to turn off the shadows, which is quite counterproductive. I set the sun's intensity to 0, but since sun is linked to sky, sky's brightness is also set to 0. If sun is not linked to sky, there is no sunrise or sunset effect.Can someone give me some guidance on what I should do?
