Optix/RTX support
Re: Optix/RTX support
Optix/RTX has the nice side effect of requiring quite some less GPU memory for the same geometry data.
This is a rendering with 60+ millions of triangles without Optix/RTX (i.e. CUDA-only):
and this with Optix/RTX (i.e. CUDA + Optix/RTX):
Note how Optix uses nearly 40% less GPU memory (4.4GB Vs 6.0GB).
that is impressive. does it scale linearly ?Note how Optix uses nearly 40% less GPU memory (4.4GB Vs 6.0GB).
Yes, it looks about linear with the number of triangles (and BVH nodes).Sharlybg wrote: Tue Jul 21, 2020 12:42 pmthat is impressive. does it scale linearly ?Note how Optix uses nearly 40% less GPU memory (4.4GB Vs 6.0GB).
2.5 will going to be a monster. Going to joke with people again with some tasty benchmark.Yes, it looks about linear with the number of triangles (and BVH nodes).
When will 2.5 build available for test ?
It is already if you know how to download artifacts from Azure but, anyway, the v2.5 branch will be merged with main one soon after the v2.4 release.
will this also be for gtx gpus for like a gtx1660 or gtx1080 or will this be rtx only and if rtx only does it not have any speed improvements for a gtx gpu or is that more work to make?
I'm not sure about the GTX1660 but the GTX1080 should definitively work, it should also be a bit faster than our current ray tracing code, even without hardware RTX.bestman8 wrote: Sat Jul 25, 2020 6:51 pm will this also be for gtx gpus for like a gtx1660 or gtx1080 or will this be rtx only and if rtx only does it not have any speed improvements for a gtx gpu or is that more work to make?
It is now possible to disable Optix (even if it is enabled and available) with the property:
context.cuda.optix.enable = 0
Is it normal to not see optix in the first alpha build of blendluxcore. i know you said it is enable by default.Dade wrote: Tue Jul 28, 2020 4:08 pm It is now possible to disable Optix (even if it is enabled and available) with the property:
