Best Friends Forever
MetinSeven
Post by MetinSeven »
Cartoon-style 3D illustration
Created using a combination of polygon subdivision modeling and Sculpt Mode
Rendered using LuxCoreRender
Concept: Michael Hacker
Hope you like it! 😊
🔗 metinseven.nl
metin-seven_stylized-artistic-3d-illustrator-cartoon-character-designer_pizza-slice-beer-bottle.png
Re: Best Friends Forever
Another wonderfull illustration.Thanks for this fresh creative art air. lovely :D
btw look like you struggle to get rid of fireflies in glass object. Do you try the shadow color trick ?
MetinSeven
Many thanks, much appreciated!
I've tried the shadow trick, but it turned the glass into more of an architectural glass type, without the nice contrast in the refractions.
I could have used denoising, but that smooths out too much detail to my liking.
In the end I actually like a bit of noise. It works like a slight grain, and avoids the image getting too smooth.
As far as I remember, it is the first time I see LuxCore (or even the old Lux) used for this kind of stylized/cartoon rendering style. Who said it wasn't possible ? It looks damn good :D
This a quite typical field of application for Cycles but I would say that LuxCore adds a little photorealism twist.
MetinSeven
Thank you David, much appreciated! 👍
LuxCoreRender is a joy to work with because everything, including the lighting, behaves exactly as you would expect in the real world. A back light really casts that broad, bright rim it would cause in real life. I love that. Compared to LuxCoreRender, Cycles suddenly feels like a semi-realistic renderer, floating somewhere between Eevee and Lux.
In other words: I won't be using Cycles anymore. 🙂
