What is new in LuxCore API v2.0 ?
Re: What is new in LuxCore API v2.0?
Post by Dade » Tue Mar 27, 2018 9:54 am
neo2068 wrote:
Tue Mar 27, 2018 7:16 am
Dade wrote:
Mon Mar 26, 2018 10:04 pm
It is a lot faster and it works :lol:
I must admit I have still aliasing problem with sharp edges but there aren't usually a lot of sharp edges in most common heterogeneous volumes (i.e. smoke, etc.).
Just compile the latest sources and try to use an heterogeneous volume with density grid (btw, I added the OpenCL support for density grid texture too).
:lol: OpenCL support is really great. Thanks for that. I tried to implement that some time ago but only got frustrated as debugging the code was a nightmare.
It always is :roll: Anyway the winning trick was to store the density grid 3D data as a 2D image map (x projected on image x and y/z on image y). I had already in place the infrastructure to encode/transfer image maps on GPUs and everything worked flawless once I used this trick (I hadn't to write any additional code).
Is there an automatic step size estimation for heterogeneous volumes?
No but the step size is now fixed (it was variable before) so if you want to render a 1 meter cube you know you are going to need a 5cm-20cm step size. It is not hard to setup once you know the step size in expressed in a real world unit.
Aliasing was bad with the old code, too, and multiple scattering volumes wasn't as bright as rendered with other renderers. I have to try it. :D
Single scatter:
Multi-scattering :D
It is also so much faster, multi-scattering at 9M samples/secs:
Odilkhan Yakubov
Post by Odilkhan Yakubov » Tue Mar 27, 2018 1:45 pm
Is it possible to add some HD Cache or add the secondary engine like Corona renderer?
Allah bless us!
Post by Dade » Tue Mar 27, 2018 1:52 pm
What does Corana do ? Do they compose rendering by doing volume rendering in a separate step with a separate engine :?:
For HD cache, do you mean the Corona light cache ?
Post by B.Y.O.B. » Tue Mar 27, 2018 2:08 pm
Some engines use different integrators for primary/secondary bounces.
E.g. V-Ray: https://docs.chaosgroup.com/display/VRA ... Parameters
edit: their nomenclature is a bit weird, I think with "primary bounces" they mean the first indirect bounce, and with "secondary bounces" all following bounces.
Maybe this image shows it: https://docs.chaosgroup.com/display/VR2R/Brute+Force+GI
Odilkhan Yakubov
Post by Odilkhan Yakubov » Tue Mar 27, 2018 2:19 pm
Seems like that, but just a little bit different
Allah bless us!
Odilkhan Yakubov
Post by Odilkhan Yakubov » Tue Mar 27, 2018 2:20 pm
Is there planned bucket rendering not Progressive refine (like now, like Cycles)?
Allah bless us!
Supporting Users
Post by Sharlybg » Tue Mar 27, 2018 2:24 pm
This is already available as Tile rendering. See option in render engine setting.
Post by B.Y.O.B. » Tue Mar 27, 2018 2:25 pm
It is already available (TILEPATH engine).
In BlendLuxCore, it is available in the render settings: Just enable the "Tiled" checkbox.
Odilkhan Yakubov
Post by Odilkhan Yakubov » Tue Mar 27, 2018 2:27 pm
Oh, its my mistake.
Allah bless us!
neo2068
Post by neo2068 » Tue Mar 27, 2018 8:53 pm
I like the new volume rendering. :D It is very fast and looks awesome.
PathOCL, multiple scattering
i7 5820K, 32 GB RAM, NVIDIA Geforce GTX 1080 + GTX 780, Windows 10 64bit, Blender 2.79b
