Hi all, I have done a few test type renders before, but this is my first scene in I would say has a deliberate set up. This was part of a talk I did on different render engines in Blender for the London Blender User Group. Would love to hear your feedback.
						First 'real' render with LuxCore
Re: First 'real' render with LuxCore
Nice start with lux. Hope you didn't get confused by the difference between Lux and cycles
the scene itself have a lot of potential considering the quantity of detailed bottle here. But you can test some brighter sunny lighting to create contrast and make it less flat. I will also enable light tracing caustics to get more realism.
In case you have some fuel left to push a bit
1__ Make some part brigter than the rest of the scene like this. use some object to stop light.
2__ Make sure that your light power and sharpness plus your camera position allow to see caustic easier. like this :
3__ With a good (high resolution) hdri from Hdrhaven you can end up with nice reflection like this :
Anyway thanks for Sharing.
Hi Sharlybg, thanks for the detailed feedback. I found the cross from cycles to lux not too bad, although I have much to learn still.
I am definitely going to do something more with this, but probably a new scene just to change things up a bit. This time I want animation to be part of it. I think one of my aims is to find a balance between relaism and speed for animation purposes.
Oh, by the way, thanks a stack for your YouTube videos. I used them to kickstart my into this renderer. So in a way you contributed to this image...
