LuxCoreUI v2.3 (LuxCore demo: http://www.luxcorerender.org)
Segmentation fault
Segmentation fault
gdb ./luxcoreui
run
backtraceCode: Select all
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 61
model name : Intel(R) Core(TM) i3-5010U CPU @ 2.10GHz
stepping : 4
microcode : 0x2f
cpu MHz : 1995.339
cache size : 3072 KB
physical id : 0
siblings : 4
core id : 0
cpu cores : 2
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 20
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb invpcid_single pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid rdseed adx smap intel_pt xsaveopt dtherm arat pln pts md_clear flush_l1d
vmx flags : vnmi preemption_timer invvpid ept_x_only ept_ad ept_1gb flexpriority tsc_offset vtpr mtf vapic ept vpid unrestricted_guest ple
bugs : cpu_meltdown spectre_v1 spectre_v2 spec_store_bypass l1tf mds swapgs itlb_multihit srbds
bogomips : 4190.21
clflush size : 64
cache_alignment : 64
address sizes : 39 bits physical, 48 bits virtual
power management:
processor : 1
cpu family : 6
model : 61
stepping : 4
microcode : 0x2f
cpu MHz : 1995.338
physical id : 0
siblings : 4
core id : 1
cpu cores : 2
apicid : 2
initial apicid : 2
fpu : yes
fpu_exception : yes
cpuid level : 20
wp : yes
bogomips : 4190.21
clflush size : 64
power management:
processor : 2
cpu family : 6
model : 61
stepping : 4
microcode : 0x2f
cpu MHz : 1995.339
physical id : 0
siblings : 4
core id : 0
cpu cores : 2
apicid : 1
initial apicid : 1
fpu : yes
fpu_exception : yes
cpuid level : 20
wp : yes
bogomips : 4190.21
clflush size : 64
power management:
processor : 3
cpu family : 6
model : 61
stepping : 4
microcode : 0x2f
cpu MHz : 1995.339
physical id : 0
siblings : 4
core id : 1
cpu cores : 2
apicid : 3
initial apicid : 3
fpu : yes
fpu_exception : yes
cpuid level : 20
wp : yes
bogomips : 4190.21
clflush size : 64
power management:
(gdb) run
Starting program: /home/hari/files/Downloads/Software/luxcorerender-v2.3-linux64/LuxCore/luxcoreui
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
[New Thread 0x7fffef332700 (LWP 12892)]
[New Thread 0x7fffeeb31700 (LWP 12893)]
[New Thread 0x7fffee330700 (LWP 12894)]
[Thread 0x7fffeeb31700 (LWP 12893) exited]
[Thread 0x7fffef332700 (LWP 12892) exited]
[Thread 0x7fffee330700 (LWP 12894) exited]
Thread 1 "luxcoreui" received signal SIGSEGV, Segmentation fault.
0x0000555555a3f8df in _glfwPlatformInit ()
(gdb) backtrace
#0 0x0000555555a3f8df in _glfwPlatformInit ()
#1 0x0000555555a3b719 in glfwInit ()
#2 0x000055555596993e in LuxCoreApp::RunApp(luxcore::RenderState*, luxcore::Film*) ()
#3 0x000055555590972c in main ()
But are you using an headless terminal ? It looks like your OpenGL support is broken. For command line rendering, without any visual feedback you should use pyluxcoretools console command.harishankar wrote: Wed Jun 24, 2020 2:00 pm Here is the output of gdb backtrace:Code: Select all
(gdb) run Starting program: /home/hari/files/Downloads/Software/luxcorerender-v2.3-linux64/LuxCore/luxcoreui [Thread debugging using libthread_db enabled] Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1". [New Thread 0x7fffef332700 (LWP 12892)] [New Thread 0x7fffeeb31700 (LWP 12893)] [New Thread 0x7fffee330700 (LWP 12894)] LuxCoreUI v2.3 (LuxCore demo: http://www.luxcorerender.org) [Thread 0x7fffeeb31700 (LWP 12893) exited] [Thread 0x7fffef332700 (LWP 12892) exited] [Thread 0x7fffee330700 (LWP 12894) exited] Thread 1 "luxcoreui" received signal SIGSEGV, Segmentation fault. 0x0000555555a3f8df in _glfwPlatformInit () (gdb) backtrace #0 0x0000555555a3f8df in _glfwPlatformInit () #1 0x0000555555a3b719 in glfwInit () #2 0x000055555596993e in LuxCoreApp::RunApp(luxcore::RenderState*, luxcore::Film*) () #3 0x000055555590972c in main ()
Not using a headless terminal. Also OpenGL works for me. At least, glxgears works fine. I am using a laptop with dual Nvidia (dedicated) and intel graphics chip. glxgears works with both primusrun and without primusrun.Dade wrote: Wed Jun 24, 2020 3:36 pmBut are you using an headless terminal ? It looks like your OpenGL support is broken. For command line rendering, without any visual feedback you should use pyluxcoretools console command.
name of display: :0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
...Code: Select all
name of display: :0
server glx vendor string: NVIDIA Corporation
