BlendLuxCore Development
Re: BlendLuxCore Development
Well that's excellent news
Currently crawling around in weird bgl OpenGL code trying to use modern OpenGL to draw the viewport render.
Somewhere in Blender I found this function which is supposed to create a NULL pointer when passed 0 as input:
Problem is it doesn't work
Blender crashes and I read somewhere that bgl.Buffer doesn't support null pointers.
Which in turn means I can't use the functions glVertexAttribPointer and glDrawElements which I need for modern OpenGL VBO drawing.
If someone wants to follow me on this quest, see issue 19.
At least OpenGL coding creates nice glitches when error handling is a bit lax (fixed by now):
def gl_buffer_void_as_long(value):
import ctypes
a = (ctypes.c_byte * 1).from_address(value)
return bgl.Buffer(bgl.GL_BYTE, 1, a)
Found out what it was: motion blur!
It steps through 2 (or 3?) frames when exporting each object (even when the object is not animated, apparently. maybe I can check that in the future).
Without motion blur it exports in 0.6 seconds. This is faster than BlendLuxCore, probably because BlendLuxCore does not have mesh caching yet so shared meshes are exported multiple times, or maybe because of other reasons.
But I have an optimization for future motion blur in mind: I read somewhere that someone refactored it from (pseudocode):
for obj in objects:
for i in blur_steps:
set_frame(i)
export(obj)
set_frame(i)
for obj in objects:
export(obj)
Yes, I have seen the Blender code only a couple of times but I have no doubt that switching frame can be an extremely expansive (really, I mean, it could involve stuff like reading different texture maps, etc.).
I found the reason why the new exporter didn't work on my side. I tried to activate the new exporter beside the old one. When I deactivate the old one all work fine. The same happens if I try to activate the old exporter after activation of the new one but the other way around.
I would never have guessed that because on my machine it works fine.
Weird stuff. Maybe we will have to add a note about it to the first release.
I would like to join in on developing blendluxcore. I have unfortunately no experience of collaborated development through github, and python is new to me too. I have made some small programs for myself over the years in free pascal using lazarus ide but nothing big.
I will start examining the blendluxcore code and try to learn how it all works.
Byob, can you think of any (easy) part of blendluxcore that I could start working on?
It's great that you're interested
However you have a lot on your plate. I'll try to write more beginner guides for the BlendLuxCore code.
This is a good opportunity to make the code as accessible to newcomers as possible.
To learn Python and the Blender API basics, I would suggest you start writing some simple Python scripts and addons in Blender first.
See https://docs.blender.org/api/2.79/ (there are some beginner guides linked in the first paragraph)
A task that's doable for a beginner would be to add more material nodes, however it's also a bit boring and tedious (if you're not super hyped to see that cool metal2 material you're implementing).
I think it might be better to think of a topic that interests you especially. Is there some LuxCore feature you want to see implemented as soon as possible?
Back when I started I did it because I came from V-Ray and wanted to use the power of AOVs. I think since I implemented AOVs I have used them two times or so in an actual project
About github and all that, I will quote the wiki:
I'll write a more detailed guide later.
So your first step is to create a github account, go to https://github.com/LuxCoreRender/BlendLuxCore and press the "fork" button on the top right of the page.If you want to contribute to LuxCore development or just submit a quick patch, the easiest way to start is to fork the repository on github.
You can then edit your fork, commit your changes and send us a pull request.
If you continue to contribute, we will eventually give you direct access to the repositories.
That sounds good, I'll start there.B.Y.O.B. wrote: ↑Wed Dec 20, 2017 4:39 pm A task that's doable for a beginner would be to add more material nodes...
You can have a look at this commit where I added the glass node: https://github.com/LuxCoreRender/BlendL ... 39fc780e82
It's a bit of a special case because it is really 3 materials (glass, roughglass and archglass) but it should show you which files to edit:
Our nodes have only one custom method that's not part of the example, the "export" method. And if you have any questions, let me know.
edit: by the way, the IDE I use is Pycharm community edition.
If you tell me your OS I can also upload a fresh LuxCore build for you, or you can try to compile yourself: http://wiki.luxcorerender.org/Compiling_LuxCore
- Create the file nodes/materials/thenewmaterial.py (e.g. glass.py or metal2.py)
- import your new class in nodes/materials/__init__.py and add it as a NodeItem
- If you need any new sockets for your material, add them to nodes/sockets.py
