u3dreal wrote: Fri May 29, 2020 12:35 pm
No access to secure file for me .. should i merge ? otherwise no check possible. maybe you can check ..
For increased security, secure files and secret variables are never accessible to pull requests coming from forks.
If you prefer not to act directly on the master branch, you could create another branch in our repo: in that case everything should work.
acasta69 wrote: Fri May 29, 2020 4:10 pm
I have updated the azure pipeline files for Windows and it's running now. I'll check the binaries as soon as they are available.
About Linux: is it enough to build only the version with neither "opencl" nor "cuda" in the directory name?
Or do you need to modify the build scripts in the "LinuxCompile" repo?
I still need to check/update the Linux build process.
I should have now updated everything and, yes, neither "opencl" nor "cuda" in the directory name are required anymore.
Dade wrote: Sun May 31, 2020 12:23 pm
I have updated the Azure pipeline files.
BlendLuxCore seems already ok, no modification necessary.
acasta69 wrote: Sun May 31, 2020 2:51 pm
Hmm there are some errors on linux side ... but yes it builds but only linux-opencl ..
I would do it but i have no clue what files are needed for linux
