LightTracing BlendLuxCore 2.3 vs. BlendLuxCore 2.4 ?
denon100
Post by denon100 »
is this behavior normal in BlendLuxCore 2.4 with LightTracing?
If the LightTracing is on or off, the material colors change.
Have otherwise made no changes.
This does not happen with BlendLuxCore 2.3.
thank you
Blender 2.8
Windos 10 Pro version 1909
Ryzen 9 3900x
RTX 2070 Super
Re: LightTracing BlendLuxCore 2.3 vs. BlendLuxCore 2.4 ?
Are you using automatic tonemapping?
Can you upload the scene?
denon100
Post by denon100 »
No matter whether tonemapping is on or off.
thank you
Lighttracing.blend
(751.26 KiB) Downloaded 452 times
It is a view port rendering with and without light tracing (PATHCPU Vs RTPATHCPU) :?: Do you get the same results in final rendering (i.e. PATHCPU Vs. PATHCPU) ?
denon100
Post by denon100 »
final rendering identical to viewport rendering :!:
by the way, everything works with the Disney material :?
as in BlendLuxCore 2.3
denon100
Post by denon100 »
am I the only one with this problem ?
Luximage
Post by Luximage »
I have the same problem with you denon100.If i change the plane material to disney or glossy or metal with roughness included to Light tracing glossiness threshold it works ok.
win 10, xeon e5620, gtx 1050 ti
blender 2.82, latest daily blendluxcore 2.4 cuda
It was a bug in MIS code when rendering env. light sources with light tracing. I should have fixed the problem.
denon100
Post by denon100 »
Hello,
and thank you very much for your endless efforts.
Thank you :P
