Motion blur not working
Please do someone know where is the object motion blur check box is in Blendluxcore ? i don't remenber where to find it.
Racleborg
Re: BlendLuxCore Development
Post by Racleborg »
(attached) -
Racleborg wrote: Fri May 01, 2020 9:59 am(attached) -
Sadly i have no success !
Blend
motion blur test.blend
(2.13 MiB) Downloaded 798 times
Working fine here with v2.3. I'll check v2.4 next.
In the future, please just open a bug report, it will tell you all the things to include in your report, like the LuxCore version you're using.
https://github.com/LuxCoreRender/BlendL ... .md&title=
B.Y.O.B. wrote: Fri May 01, 2020 2:00 pm Working fine here with latest v2.4 sources.
Ok i will test the last blendluxcore 2.4 build. by the way i didn't even though about a bug (just a wrong setting from my side).
It also works with latest v2.4 here.
should i download the lastest CUDA / Opencl Luxcorerenderer builds . i fear the mess and bug arround it i'am rendering an animation :?
If you need a stable build, then of course you should stick to the latest stable version (v2.3 in this case).
Latest builds should only be used for testing, not for any serious work.
B.Y.O.B. wrote: Fri May 01, 2020 2:17 pm If you need a stable build, then of course you should stick to the latest stable version (v2.3 in this case).
Sure but there is also the fact that i get my feet in 2.4 because of some new feature/Bug fix i require and now 2.4 build seem a bit messy. but here we go i will jump in the board :roll:
Work fine with 2.4 Cuda/Opencl. just remenber i can have both build on same system and switch between them. a real pleasure :D
