Did you do any profiling yet to find the hotspots in the interpreter?Dade wrote: Thu Apr 30, 2020 2:30 pm I assume I can regain some performance (but only in CUDA): for the textures alone, there is a "switch(textureType)" with 60+ cases, in CUDA it can be done with a jump table with function pointers.
v2.3 Vs v2.4 performance
Re: v2.3 Vs v2.4 performance
I have (micro-)kernel execution times, each kernel does a quite specific task. The main bottle neck is mostly the BSDF sampling.B.Y.O.B. wrote: Thu Apr 30, 2020 2:34 pmDid you do any profiling yet to find the hotspots in the interpreter?Dade wrote: Thu Apr 30, 2020 2:30 pm I assume I can regain some performance (but only in CUDA): for the textures alone, there is a "switch(textureType)" with 60+ cases, in CUDA it can be done with a jump table with function pointers.
Comparison with v2.2 is even scarier:
this is a lot even between 2.2 and 2.3 there is half performance lost.epilectrolytics wrote: Fri May 01, 2020 9:06 am Comparison with v2.2 is even scarier:
Yep, I'm totally stunned.Sharlybg wrote: Fri May 01, 2020 9:30 am this is a lot even between 2.2 and 2.3 there is half performance lost.![]()
Maybe we need Optix RTX support to regain the render speed we already had last year??
And AMD users are kind of screwed right now
Here are results with GTX970 (2.3 vs. 2.4 build 20200430.12):
On this card CUDA underperforms OpenCL quite a bit...
Anyone else with this or similar GPU series can confirm?
P.S. With the very latest build, LuxCoreUI exits without any error message while evaluating PhotonGI best radius:
[LuxRays][1.828] [MBVHKernel] Compiler options: -D LUXRAYS_OPENCL_KERNEL -D PARAM_RAY_EPSILON_MIN=0.0001f -D PARAM_RAY_EPSILON_MAX=0.1f -D LUXRAYS_OPENCL_DEVICE -cl-fast-relaxed-math -cl-mad-enable
[LuxRays][1.828] [MBVHKernel] Compiling kernels
[LuxRays][1.828] [MBVHKernel] Program cached
[LuxCore][1.859] [PathOCLRenderEngine] OpenCL task count: 262144
[LuxCore][1.859] [PathOCLBaseRenderEngine] OpenCL max. page memory size: 1048576Kbytes
[LuxCore][1.859] PhotonGI evaluating best radius
C:\Users\Alessandro\Desktop\luxcorerender-latest-win64-cuda\scenes\LuxCore2.1Benchmark\LuxCoreScene>Re: v2.3 Vs v2.4 performance
A 970 GTX can not be 7 times slower than a 2070 RTX
Indeed! I dont' understand if it can be something broken on my system or not...
I tested both with Azure-built and self-built binaries, results are the same.
I should have fixed this problem.acasta69 wrote: Fri May 01, 2020 1:06 pm P.S. With the very latest build, LuxCoreUI exits without any error message while evaluating PhotonGI best radius:
