PATHGPU with OpenCL and CUDA support
u3dreal
Re: PATHGPU with OpenCL and CUDA support
Post by u3dreal »
epilectrolytics wrote: Tue Apr 28, 2020 7:06 pm
 Library not loaded: @rpath/libnvrtc.10.1.dylib
  Referenced from: /Users/me/Library/Application Support/Blender/2.82/scripts/addons/BlendLuxCore/bin/pyluxcore.so
  Reason: image not found
Are you sure you have CUDA 10.1 installed ? Does /Developer/NVIDIA/CUDA-10.1/lib/libnvrtc.10.1.dylib exist ?
Will have to check with my other mac.
portfolio http://q3de.com/
Post by epilectrolytics »
u3dreal wrote: Tue Apr 28, 2020 7:41 pm Are you sure you have CUDA 10.1 installed ? Does /Developer/NVIDIA/CUDA-10.1/lib/libnvrtc.10.1.dylib exist ?
Ah sorry, my nVidia Web driver told me I'm up to date so I thought I have everything ready but this is a developer's thing?
Can it be downloaded for free somewhere without an account?
Edit: Just downloading this and will get back later.
Edit II: Do I need Xcode too ??
u3dreal
Post by u3dreal »
I do not provide all the nvidia stuff .. you need to install 10.1 Cuda Toolkit full. Not just the driver.
You might also do
install_name_tool -change @rpath/libnvrtc.10.1.dylib @rpath/libnvrtc.dylib /Users/YOURUSERNAME/Library/Application Support/Blender/2.82scripts/addons/BlendLuxCore/bin/pyluxcore.so
This might enable other versions of cuda.
u3dreal
Post by u3dreal »
epilectrolytics wrote: Tue Apr 28, 2020 7:55 pm Edit II: Do I need Xcode too ??
No the cuda installer should be enough.
https://developer.nvidia.com/cuda-10.1- ... rsion=1013
Thanks for the explanation.
I'm not going to do that, way to much effort for something nice to have but not really needed given my powerful PC.
My main system is still 10.12.6, on the 10.13.6 partition there is only 11GB free space, not enough for those spacious development kits.
But thanks anyways :)
u3dreal
Post by u3dreal »
You could download the network installer
https://developer.nvidia.com/cuda-10.1- ... dmgnetwork
and run it with
-s nvcc_10.1 cudart_10.1 nvrtc_10.1 nvrtc_dev_10.1
from the terminal.
this will do a minimal install.
u3dreal wrote: Tue Apr 28, 2020 8:03 pm
In Windows version, we include the NVRTC DLL too :idea:
u3dreal
Post by u3dreal »
Dade wrote: Tue Apr 28, 2020 9:07 pm In Windows version, we include the NVRTC DLL too :idea:
Oh i missed that thanks ! edited
u3dreal wrote: Tue Apr 28, 2020 8:22 pm and run it with
from the terminal.
I have no idea what that means :?
Instead I installed the driver & toolkit but not the samples, and so could make the add-on work.
But when trying to render with the cuda setting there is a BVH kernel compilation error.
I updated the cuda driver (418.163) via system preferences and apparently still the nVidia web-driver is in use?
Do I have to run some app from the newly installed CUDA developer stuff first to activate it?
libnvrtc.10.1.dylib exists in the bin folder.
u3dreal
Post by u3dreal »
Can you run blender from terminal and post the output ?
This is the driver verision i run.
