It is written with PySide (aka QT4) and designed with QtDesigner. The GUI can be accessed with the following commands:
pyluxcoretool
or
pyluxcoretool netnodeui
pyluxcoretool
or
~/P/l/L/t/LuxCore› ./pyluxcoretool
File "pyluxcoretool.py", line 42, in <module>
File "/tmp/_MEIdbMKTC/pyluxcoretools.zip/pyluxcoretools/pyluxcorenetconsole/ui.py", line 25, in <module>
ImportError: No module named 'PySide'
[28652] Failed to execute script pyluxcoretoolCode: Select all
make -j 12 pyluxcoretools ; python3 samples/pyluxcoretool/pyluxcoretool.py netnodeuiWhen I run this, the second command crashes with SIGSEV.Dade wrote: Sat Mar 17, 2018 1:08 amCode: Select all
This also works in a Python3 interpreter.Dade wrote: Sat Mar 17, 2018 1:08 am Note: I don't "import PySide", I do "import PySide.QtCore" and "PySide.QtGui"
cmake -DCMAKE_BUILD_TYPE=Debug .
make -j8Code: Select all
==12586== Process terminating with default action of signal 11 (SIGSEGV)
==12586== Bad permissions for mapped region at address 0x216296
==12586== at 0x216296: ???
==12586== by 0x81200E7: std::future_category() (in /home/simon/Projekte/luxcore_build/LinuxCompile/LuxCore/lib/pyluxcore.so)
==12586== by 0x9C22718: ??? (in /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19)
==12586== by 0x40101D9: call_init.part.0 (dl-init.c:78)
==12586== by 0x40102C2: call_init (dl-init.c:36)
==12586== by 0x40102C2: _dl_init (dl-init.c:126)
==12586== by 0x4014CFF: dl_open_worker (dl-open.c:577)
==12586== by 0x4010093: _dl_catch_error (dl-error.c:187)
==12586== by 0x401444A: _dl_open (dl-open.c:661)
==12586== by 0x541F02A: dlopen_doit (dlopen.c:66)
==12586== by 0x541F62C: _dlerror_run (dlerror.c:163)
==12586== by 0x541F0C0: dlopen@@GLIBC_2.2.5 (dlopen.c:87)
==12586==
==12586== HEAP SUMMARY:
==12586== in use at exit: 3,053,706 bytes in 6,983 blocks
==12586== total heap usage: 26,385 allocs, 19,402 frees, 16,015,063 bytes allocatedCode: Select all
import sys
from PySide.QtCore import *
from PySide.QtGui import *
# Create a Qt application
app = QApplication(sys.argv)
# Create a Label and show it
label = QLabel("Hello World")
label.show()
# Enter Qt application main loop
app.exec_()
sys.exit()
david@i7-3930k:~/projects/luxcorerender/LuxCore$ python3
Python 3.4.3 (default, Nov 28 2017, 16:41:13)
[GCC 4.8.4] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import sys
... app = QApplication(sys.argv)
... label = QLabel("Hello World")
>>> label.show()
... app.exec_()
0
>>> sys.exit()
[2]+ Terminated python3 samples/pysideluxcoredemo/pysideluxcoredemo.py
Collecting PySide
Using cached PySide-1.2.4.tar.gz
Complete output from command python setup.py egg_info:
only these python versions are supported: [(2, 6), (2, 7), (3, 2), (3, 3), (3, 4)]It works:Dade wrote: Sat Mar 17, 2018 8:52 am Does it work aside from "import PySide" ? Try to run on normal python3 interpreter:
Ok I'll try to reinstall. Yesterday night I compiled it with multithreading, maybe that killed it.
Because I don't know how to use gdb
make -j 12 pyluxcoretools ; python3 samples/pyluxcoretool/pyluxcoretool.py netnodeCode: Select all
david@i7-3930k:~/projects/luxcorerender/LuxCore$ make -j 12 pyluxcoretools
Built target pyluxcoretools
david@i7-3930k:~/projects/luxcorerender/LuxCore$ gdb python3
GNU gdb (Ubuntu 7.7.1-0ubuntu5~14.04.3) 7.7.1
Copyright (C) 2014 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from python3...(no debugging symbols found)...done.
(gdb) r samples/pyluxcoretool/pyluxcoretool.py netnodeui
