Looking for someone to update a scene (paid job)
tvvladimir
Post by tvvladimir »
Hello,
Looking for someone to help me out. I'm not a render specialist. I'm just using the files and scenes that someone made for me a long time ago.
I have a LuxCore scene. It was previously updated from Luxrender (Luxblend).
1. I need to update the scene from LuxCore's previous versions to v.2.3. Something is wrong and I can't update it.
2. Add new materials. All 3D objects are included. I will supply picture references and other stuff needed.
3. Update materials and other stuff needed to make the render more (very) realistic. Currently, it is not as realistic as needed. Just overall it looks very flat.
4. Luxrender (Luxblend) used to render the files in a standalone Luxrender window. I could adjust Tonemapping (shatter, gamma, and other) after the render was done. Is it still possible to do post-processing (increase, decrease Gamma for example)? I need a quick explanation of how to do it.
5. Final step: Make sure the render is working on my machine, if anything goes wrong, help me out with the process.
Let me know how much it will cost me. Payment after the job.
Если что я по русски говорю.
Example render from LuxCore
Example render from Luxblend
Thank for the answer in advance,
Vladimír Ťažev
Skype: tvvladimir
WhatsApp: +421 908 399 063
DEBIHOOD
Re: Looking for someone to update a scene (paid job)
Post by DEBIHOOD »
tvvladimir wrote: Mon Apr 06, 2020 12:50 pm 4. Luxrender (Luxblend) used to render the files in a standalone Luxrender window. I could adjust Tonemapping (shatter, gamma, and other) after the render was done. Is it still possible to do post-processing (increase, decrease Gamma for example)? I need a quick explanation of how to do it.
You can change gamma and exposure directly from blender ui, it was also available in older blender versions
Вы можете изменять гамму и экспозицию прямо из интерфейса blender, это было доступно и в старых версиях blender.
https://docs.blender.org/manual/en/2.82 ... ement.html
tvvladimir
Спасибо большое за ответ, оказывается рендеринг не работал т.к. Cycles тоже нужно включить. Я нашёл человека, спасибо за ответ.
