I would like to use KernelCacheFill() to compile the kernels for viewport and final render in one go, however KernelCacheFill() currently does not support to pass in the values of min. and max. epsilon.
The easiest way to support this would be to allow to pass in config properties to KernelCacheFill() by changing this line:
https://github.com/LuxCoreRender/LuxCor ... l.cpp#L284
from
Properties cfgProps;Code: Select all
Properties cfgProps = config;
