BlendLuxCore: Save image while render is paused
BYOB please can you help me ? I want to know if blender api allow to save a render while being in pause ?
Re: BlendLuxCore Development
Blender API probably not, but LuxCore allows it.
However, it will lack Blender's color management (filmic etc.) and compositing.
You mean image will be saved as Exr. So we can just reload them automatically and save to jpg so they get the ajustment applied.B.Y.O.B. wrote: Mon Apr 06, 2020 6:32 pm Blender API probably not, but LuxCore allows it.
But anyway step by step. Can we have the first stage of save while rendering.
After this line, you can insertSharlybg wrote: Mon Apr 06, 2020 6:50 pm But anyway step by step. Can we have the first stage of save while rendering.
engine.session.GetFilm().SaveOutputs()
Re: BlendLuxCore: Save image while render is paused
Thank you so much
What if i want it to be the blendfile folder to be the automatic output ?
I hope the file will not be rewrite each time i hit pause. So i can keep each image file.
I'm not sure if the LuxCore API offers a way to pass a filepath to SaveOutputs(), this is a question for Dade.Sharlybg wrote: Mon Apr 06, 2020 7:13 pm What if i want it to be the blendfile folder to be the automatic output ?
You have to rename the images or move them somewhere else if you want to prevent them from being overwritten.Sharlybg wrote: Mon Apr 06, 2020 7:13 pm I hope the file will not be rewrite each time i hit pause. So i can keep each image file.
- alpistinho
- Developer
I guess you could probably do something like:You have to rename the images or move them somewhere else if you want to prevent them from being overwritten.
import os
from datetime import datetime
os.rename('a.exr', '{}.exr'.format(datetime.now().strftime('%Y-%m-%d-%H-%M-%S')
You may also want to put the absolute path instead of the relative
There is the "SaveOutput()" for that but Alpistinho's solution is simpler.
The first code line by BYOB seem to not give me any result. there is no file saved and i have to search in all folder as i don't know wich exact folder get the file. but a quick search "exr" inside addon folder show nothing.
Alpistinho can you upload you're working modified final.py file so i can overwritte mine and be sure instruction are the same ?
I'm a bit overhelming.
- alpistinho
- Developer
I hadn't even seen the code before, but I came up with that:Sharlybg wrote: Mon Apr 06, 2020 7:45 pm The first code line by BYOB seem to not give me any result. there is no file saved and i have to search in all folder as i don't know wich exact folder get the file. but a quick search "exr" inside addon folder show nothing.
if LuxCoreDisplaySettings.paused:
if not engine.session.IsInPause():
engine.session.Pause()
utils_render.update_status_msg(stats, engine, depsgraph.scene, config, time_until_film_refresh=0)
engine.framebuffer.draw(engine, engine.session, depsgraph.scene, render_stopped=False)
engine.update_stats("", "Paused")
# Our crappy patch here
import os
os.rename('a.exr', '{}.exr'.format(datetime.now().strftime('%Y-%m-%d-%H-%M-%S')))
