Viewport and final are not matching each other.
Blend :
Displacement: mismatch between viewport and final render
Re: Displacement: mismatch between viewport and final render
You have to apply the scale on the object with displacement, then multiply the displacement height with the applied scale (i.e. 10 in this case).
- Attachments
- Antelope__cayon_fixed.blend
- (2.09 MiB) Downloaded 307 times
I'm honestly considering to export every object with scale != 1 as instance even in final render at this point, because of tons of mismatches between render and viewport like this one.
What Covid19 remedyYou have to apply the scale on the object with displacement, then multiply the displacement height with the applied scale (i.e. 10 in this case).
More seriously this isn't a long term solution. I like the current viewport behaviour.
Wanted to make a Tutorial about it but this behaviour add a complexity layer we shouldn't have or teach to someone.I'm honestly considering to export every object with scale != 1 as instance even in final render at this point, because of tons of mismatches between render and viewport like this one.
BuUUUT Am I sure to be alive 5 days from now with this time at my disposal
going to make the tutorial right now
Now it is a mismatch between texture transformation displacement. normally it should be stretched.
final and viewport look identical to me, am I missing something?
yes you miss. i mean in the viewport displacement doesn't match the voronoi texture stretching. connect the displacement node to see if it match texture transformation.B.Y.O.B. wrote: Mon Mar 30, 2020 10:16 am final and viewport look identical to me, am I missing something?
My bad i didn't select the right mapping transformation mode (Should be UV not Global)
I think there's a bug here.
