LuxCoreRender v2.3alpha binaries for MacOS
u3dreal has compiled and packed together the binaries of v2.3 alpha for MacOS: http://q3de.com/research/luxcorerender-for-osx-10-13
Re: LuxCoreRender v2.3alpha binaries for MacOS
Wow miracle still happen. Wonderfull job. Very inspiring.Dade wrote: Sat Dec 07, 2019 10:01 am u3dreal has compiled and packed together the binaries of v2.3 alpha for MacOS: http://q3de.com/research/luxcorerender-for-osx-10-13
Great stuff, thanks sooo much for this early christmas present!
LuxCoreRender v2.3alpha in Blender 2.81 on MacOS High Sierra, never thought it would happen so fast!
So far everything works fine on my old MacBook, even OpenCL on GT750M works very well, better than in v2.1!
Only issues are with Iris Pro graphics, an old problem with no relevance as the thing is normally disabled by default.
I don't see the need for a 2.2 release either.
Yes my Intel Iris also has some issues i think mainly because of missing RAM since it works on small scenes.
Good to know it works !! thanks !
portfolio http://q3de.com/
Because this is the News section I'm continuing with issue reports here at the general MacOS thread
OK automated builds is working .
get the latest MacOS binaries here https://github.com/LuxCoreRender/LuxCore/releases
BlendLuxCore osx daily build is also working.
https://github.com/LuxCoreRender/BlendL ... tag/latest
make sure to give denoise a chmod 755.
Somehow this get's introduced again in the packing process on azure on linux. We will find out how.
LuxCoreRender latest does not have this issue. So if you have problems get denoise from there and copy it.
Just do chmod 755 /Users/!you!/Library/Application Support/Blender/YOURBLENDERVERSION/scripts/addons/BlendLuxCore/bin/denoise
in the terminal after installation. !you! is your username of course !
I wonder if someone is using lux on mac now ? Let me know if it works for you !
cheers
u3dreal
cheers
u3dreal
Spartacus1
u3dreal, in MacOS the command is missing the version.
For version 2.82 it will be:
chmod 755 /Users/your username/Library/Application\ Support/Blender/2.82/scripts/addons/BlendLuxCore/bin/denoise
Best Regards
Best Regards
OK thanks for pointing it out. But 2.3 should not work with 2.82 .... due to libs not updatedSpartacus1 wrote: Sun Mar 29, 2020 1:19 am u3dreal, in MacOS the command is missing the version.
Best Regards
