Luxcore is very slow and freezes
pixel_peeper
Post by pixel_peeper »
I really like LuxCore but every time I try to use it for a project it's a pain. It's extremely slow when previewing the render in viewport, everything become laggy, changing almost any parameter and moving the viewport takes years to do. I can't understand why, my pc has an i7 8700K with a GTX 1070Ti and with Cycles is very smooth and responsive, with LuxCore is like using a Pentium 4. Sometimes Blender stops working and I need to force close and reopen it.
software:
Windows 10 Pro 1909
Blender 2.82.7
LuxCore 2.3
but this occurred also with older version of Win, Blender and LuxCore.
Please help me to obtain a decent performance because it would be awesome to use LuxCore more often! Thanks!!
Re: Luxcore is very slow and freezes
Does this happen even with very simple scenes (default cube)?
Are you rendering on CPU or GPU?
Have you tried updating your graphics driver?
pixel_peeper
B.Y.O.B. wrote: Mon Mar 23, 2020 10:17 pm Does this happen even with very simple scenes (default cube)?
Oscar9531
Post by Oscar9531 »
the same for me, it is very slow to work interactively
Here, it feels as snappy as before.
Latest commits from today (LuxCore 2bc28dca8, BlendLuxCore 9f3932b -- homebuild) on W10 with Blender 2.81a.
But IIRC, it's been mentioned that Blender is getting slower with every iteration until LTS or "everything nodes" (rewrite).
pixel_peeper wrote: Tue Mar 24, 2020 4:39 pm
I guess something went wrong when sending your answer, because all I see is my own quote?
pixel_peeper
B.Y.O.B. wrote: Wed Mar 25, 2020 2:25 pm I guess something went wrong when sending your answer, because all I see is my own quote?
Yep, sorry!
this happens also with simple scenes (liek suzanne with diff and nrm and hdri light), I'm rendering with GPU but the issue is when working in the viewport.
I've updatet my driver but nothing changed.
pixel_peeper
the only way is to set the viewport render with CPU, it's way less slow but at this point the problem is the intrinsic slowness compared to gpu in ray tracing speed.
Since you are using v2.3, it might just be the kernel recompilations?
However some other settings for OpenCL viewport were also not optimal.
Can you check with a latest build of v2.4? https://github.com/LuxCoreRender/BlendL ... tag/latest
pixel_peeper
with the latest version the selection of the device in the viewport is automatic right?
It seems to be even slower, here you can find the complete output of the console, I hope that can be useful:
Read prefs: C:\Users\Umby\AppData\Roaming\Blender Foundation\Blender\2.82\config\userpref.blend
found bundled python: C:\Program Files\Blender Foundation\Blender 2.82\2.82\python
cmolcore imported with success! v1.08
BlendLuxCore 2.4alpha0 registered (with pyluxcore 2.4alpha0)
Warning: property 'release_confirm' not found in keymap item 'OperatorProperties'
Read blend: D:\****\****\****.blend
[Engine/Viewport] New session
[Exporter] Creating session
[SDL][24.219] Camera type: perspective
[SDL][24.219] Camera position: Point[0, 0, 13.5815]
[SDL][24.219] Camera target: Point[0, 0, 12.5815]
[SDL][24.219] Camera clipping plane disabled
[SDL][24.235] Texture definition: 2491235082344Color
[SDL][24.235] Reading texture map: D:\****\****\Paper001_2K\Paper001_2K_COLOR.png
libpng warning: iCCP: known incorrect sRGB profile
[SDL][24.313] Texture definition: 2491235080856Color
[SDL][24.313] Texture definition: 2491235073416Color
[SDL][24.313] Reading texture map: D:\****\****\Paper001_2K\Paper001_2K_ROUGH.png
[SDL][24.360] Texture definition: 2491235088792Bump
[SDL][24.360] Reading texture map: D:\****\****\Paper001_2K\Paper001_2K_NRM.png
[SDL][24.391] Texture definition: 2491235088792Bump_normalmap
[SDL][24.391] Texture definition: 2491235083832Color
[SDL][24.391] Texture definition: 2491235077384Color
[SDL][24.391] Texture definition: 2491235087304Color
[SDL][24.391] Texture definition: 2491235074904Color
[SDL][24.391] Texture definition: 2491235078872Bump
[SDL][24.391] Texture definition: 2491235078872Bump_normalmap
[SDL][24.391] Texture definition: 2491235084328Bump
[SDL][24.391] Reading texture map: D:\****\****\logo_NRM.png
[SDL][24.516] Texture definition: 2491235084328Bump_normalmap
[SDL][24.516] Texture definition: 2491235088296Value
[SDL][24.516] Texture definition: 2491235078376Color
[SDL][24.516] Texture definition: 2491235850312Color
[SDL][24.516] Texture definition: 2491235075400Color
[SDL][24.516] Texture definition: 2491235077880Bump
[SDL][24.516] Texture definition: 2491235077880Bump_normalmap
[SDL][24.516] Material definition: 2492985178648
[SDL][24.516] Material definition: 2492985178984
[SDL][24.516] Material definition: 2492985172936
[SDL][24.516] Material definition: 2492984749448_AREA_LIGHT_MAT
[SDL][24.516] Material definition: 2492984762840_AREA_LIGHT_MAT
[SDL][24.516] Material definition: 2492985179656
[SDL][24.516] The 24929847494480 object is a light sources with 2 triangles
[SDL][24.516] The 24929847628400 object is a light sources with 2 triangles
[SDL][24.516] Scene objects count: 7
[SDL][24.516] Light definition: __WORLD_BACKGROUND_LIGHT__
[SDL][24.516] Reading texture map: D:\****\****\..\..\3D Objects\HDRI\skylit_garage_8k.hdr
[LuxCore][25.813] Configuration:
[LuxCore][25.813]   path.pathdepth.total = 7
[LuxCore][25.813]   path.pathdepth.diffuse = 5
[LuxCore][25.813]   path.pathdepth.glossy = 5
[LuxCore][25.813]   path.pathdepth.specular = 6
[LuxCore][25.813]   path.hybridbackforward.enable = 0
[LuxCore][25.813]   path.hybridbackforward.partition = 0
[LuxCore][25.813]   path.hybridbackforward.glossinessthreshold = 0.048999998718500137
[LuxCore][25.813]   rtpath.resolutionreduction.preview = 4
[LuxCore][25.813]   rtpath.resolutionreduction.preview.step = 2
[LuxCore][25.813]   rtpath.resolutionreduction = 2
[LuxCore][25.813]   opencl.cpu.use = 0
[LuxCore][25.813]   opencl.gpu.use = 1
[LuxCore][25.813]   opencl.devices.select = "1"
[LuxCore][25.813]   opencl.native.threads.count = 0
[LuxCore][25.813]   renderengine.type = "RTPATHOCL"
[LuxCore][25.813]   sampler.type = "TILEPATHSAMPLER"
[LuxCore][25.813]   film.width = 610
[LuxCore][25.813]   film.height = 610
[LuxCore][25.813]   film.filter.type = "BLACKMANHARRIS"
[LuxCore][25.813]   film.filter.width = 1.5
[LuxCore][25.813]   lightstrategy.type = "LOG_POWER"
[LuxCore][25.813]   scene.epsilon.min = 9.9999997473787516e-06
[LuxCore][25.813]   scene.epsilon.max = 0.10000000149011612
[LuxCore][25.813]   film.opencl.enable = 1
[LuxCore][25.813]   film.opencl.device = 0
[LuxCore][25.813]   path.forceblackbackground.enable = 0
[LuxCore][25.813]   renderengine.seed = 1
[LuxCore][25.813]   film.outputs.0.type = "RGB_IMAGEPIPELINE"
[LuxCore][25.813]   film.outputs.0.index = 0
[LuxCore][25.813]   film.outputs.0.filename = "RGB_IMAGEPIPELINE_0.png"
[LuxCore][25.813]   film.imagepipelines.0.0.type = "NOP"
[LuxCore][25.813]   film.imagepipelines.0.1.type = "TONEMAP_LINEAR"
[LuxCore][25.813]   film.imagepipelines.0.1.scale = 1
[LuxCore][25.813]   film.imagepipelines.0.radiancescales.0.enabled = 1
[LuxCore][25.813]   film.imagepipelines.0.radiancescales.0.globalscale = 1
[LuxCore][25.813]   film.imagepipelines.0.radiancescales.0.rgbscale = 1 1 1
[LuxCore][25.813]   batch.haltspp = 300
[LuxCore][25.813]   batch.halttime = 0
[LuxCore][25.813] File Name Resolver Configuration:
Export took 1.6 s
[LuxCore][25.813] Film resolution: 610x610
[SDL][25.813] Film output definition: RGB_IMAGEPIPELINE [image.png]
[SDL][25.813] Image pipeline: film.imagepipelines.0
[SDL][25.828] Image pipeline step 0: NOP
[SDL][25.828] Image pipeline step 1: TONEMAP_LINEAR
[SDL][25.828] Film output definition: RGB_IMAGEPIPELINE [RGB_IMAGEPIPELINE_0.png]
[LuxRays][25.828] OpenCL Platform 0: NVIDIA Corporation
[LuxRays][25.828] Device 0 name: Native
[LuxRays][25.828] Device 0 type: NATIVE_THREAD
[LuxRays][25.828] Device 0 compute units: 1
[LuxRays][25.828] Device 0 preferred float vector width: 4
[LuxRays][25.828] Device 0 max allocable memory: 0MBytes
[LuxRays][25.828] Device 0 max allocable memory block size: 0MBytes
[LuxRays][25.828] Device 1 name: GeForce GTX 1070 Ti
[LuxRays][25.828] Device 1 type: OPENCL_GPU
[LuxRays][25.828] Device 1 compute units: 19
[LuxRays][25.828] Device 1 preferred float vector width: 1
[LuxRays][25.828] Device 1 max allocable memory: 8192MBytes
[LuxRays][25.828] Device 1 max allocable memory block size: 2048MBytes
[LuxRays][25.828] Creating 1 intersection device(s)
[LuxRays][25.828] Allocating intersection device 0: GeForce GTX 1070 Ti (Type = OPENCL_GPU)
[LuxCore][25.828] OpenCL devices used:
[LuxCore][25.828] [GeForce GTX 1070 Ti Intersect]
[LuxCore][25.828]   Device OpenCL version: OpenCL 1.2 CUDA
[LuxCore][25.828] Native devices used: 0
[LuxCore][25.828] Configuring 1 OpenCL render threads
[LuxCore][25.828] Configuring 0 native render threads
new framebuffer
[LuxRays][26.157] Preprocessing DataSet
[LuxRays][26.157] Total vertex count: 25562
[LuxRays][26.157] Total triangle count: 46696
[LuxRays][26.157] Preprocessing DataSet done
[LuxRays][26.188] Adding DataSet accelerator: MBVH
[LuxRays][26.188] Total vertex count: 25562
[LuxRays][26.188] Total triangle count: 46696
[LuxRays][26.188] Building Multilevel Bounding Volume Hierarchy: 7 leafs
[LuxRays][26.188] BVH Dataset preprocessing time: 0ms
[LuxRays][26.188] BVH builder: EMBREE_BINNED_SAH
[LuxRays][26.188] BVH build hierarchy time: 0ms
[LuxRays][26.188] BVH total build time: 0ms
[LuxRays][26.188] Total BVH memory usage: 1065Kbytes
[LuxRays][26.203] BVH build hierarchy time: 14ms
[LuxRays][26.203] BVH total build time: 14ms
[LuxRays][26.203] Total BVH memory usage: 1064Kbytes
[LuxRays][26.203] BVH Dataset preprocessing time: 0ms
[LuxRays][26.203] BVH builder: EMBREE_BINNED_SAH
[LuxRays][26.203] BVH build hierarchy time: 0ms
[LuxRays][26.203] BVH total build time: 0ms
[LuxRays][26.203] Total BVH memory usage: 28Kbytes
[LuxRays][26.219] BVH build hierarchy time: 15ms
[LuxRays][26.219] BVH total build time: 15ms
[LuxRays][26.219] Total BVH memory usage: 0Kbytes
[LuxRays][26.219] BVH Dataset preprocessing time: 0ms
[LuxRays][26.219] BVH builder: EMBREE_BINNED_SAH
[LuxRays][26.219] BVH build hierarchy time: 0ms
[LuxRays][26.219] BVH total build time: 0ms
[LuxRays][26.219] Building Multilevel Bounding Volume Hierarchy root tree
[LuxRays][26.219] MBVH root tree builder: EMBREE_BINNED_SAH
[LuxRays][26.219] MBVH build time: 30ms
[LuxRays][26.219] Total Multilevel BVH memory usage: 2159Kbytes
[LuxRays][26.313] [Device GeForce GTX 1070 Ti Intersect] MBVH mesh vertices buffer size: 299Kbytes
[LuxRays][26.313] [Device GeForce GTX 1070 Ti Intersect] MBVH nodes buffer size: 2159Kbytes
[LuxRays][26.313] [Device GeForce GTX 1070 Ti Intersect] MBVH leaf transformations buffer size: 448bytes
[LuxCore][26.313] Tiles initialization time: 0.00 secs
[LuxCore][26.313] [PathOCLBaseRenderEngine] OpenCL max. page memory size: 2097152Kbytes
[LuxCore][26.313] Compile Geometry
[LuxCore][26.313] Scene geometry compilation time: 0ms
[LuxCore][26.313] Compile 53 Textures
[LuxCore][26.328] Texture evaluation ops count: 197
[LuxCore][26.328] Texture evaluation max. stack size: 8
[LuxCore][26.328] Textures compilation time: 0ms
[LuxCore][26.328] Compile 6 Materials
[LuxCore][26.328] Material evaluation ops count: 42
[LuxCore][26.328] Material evaluation max. stack size: 8
[LuxCore][26.328] Material compilation time: 0ms
[LuxCore][26.328] Compile Lights
[LuxCore][26.657] Lights compilation time: 328ms
[LuxCore][26.657] Compile ImageMaps
[LuxCore][26.891] Image maps page(s) count: 1
[LuxCore][26.891]  RGB channel page 0 size: 457386Kbytes
[LuxCore][26.891] Image maps compilation time: 234ms
[LuxCore][26.907] Always enabled OpenCL code:
[LuxCore][26.907] Compile Geometry
[LuxCore][26.907] Scene geometry compilation time: 0ms
[LuxCore][26.907] Compile 53 Textures
[LuxCore][26.907] Texture evaluation ops count: 197
[LuxCore][26.907] Texture evaluation max. stack size: 8
[LuxCore][26.907] Textures compilation time: 0ms
[LuxCore][26.907] Compile 6 Materials
[LuxCore][26.907] Material evaluation ops count: 42
[LuxCore][26.907] Material evaluation max. stack size: 8
[LuxCore][26.907] Material compilation time: 0ms
[LuxCore][26.907] Compile Lights
[LuxCore][27.157] Lights compilation time: 250ms
[LuxCore][27.157] Compile ImageMaps
[LuxCore][27.422] Image maps page(s) count: 1
[LuxCore][27.422]  RGB channel page 0 size: 457386Kbytes
[LuxCore][27.422] Image maps compilation time: 233ms
[LuxCore][27.422] Starting 1 OpenCL render threads
[LuxRays][27.438] [Device GeForce GTX 1070 Ti Intersect] RADIANCE_PER_PIXEL_NORMALIZEDs[0] buffer size: 5833Kbytes
[LuxRays][27.438] [Device GeForce GTX 1070 Ti Intersect] Camera buffer size: 5468bytes
[LuxRays][27.438] [Device GeForce GTX 1070 Ti Intersect] Normals buffer size: 299Kbytes
[LuxRays][27.438] [Device GeForce GTX 1070 Ti Intersect] UVs buffer size: 399Kbytes
[LuxRays][27.438] [Device GeForce GTX 1070 Ti Intersect] Triangle normals buffer size: 547Kbytes
[LuxRays][27.438] [Device GeForce GTX 1070 Ti Intersect] Vertices buffer size: 299Kbytes
[LuxRays][27.438] [Device GeForce GTX 1070 Ti Intersect] Triangles buffer size: 547Kbytes
[LuxRays][27.438] [Device GeForce GTX 1070 Ti Intersect] Mesh description buffer size: 2156bytes
[LuxRays][27.438] [Device GeForce GTX 1070 Ti Intersect] ImageMap descriptions buffer size: 140bytes
[LuxRays][27.438] [Device GeForce GTX 1070 Ti Intersect] ImageMaps buffer size: 457386Kbytes
[LuxRays][27.594] [Device GeForce GTX 1070 Ti Intersect] Textures buffer size: 15Kbytes
[LuxRays][27.594] [Device GeForce GTX 1070 Ti Intersect] Texture evaluation ops buffer size: 1576bytes
[LuxRays][27.594] [Device GeForce GTX 1070 Ti Intersect] Texture evaluation stacks buffer size: 3072Kbytes
[LuxRays][27.594] [Device GeForce GTX 1070 Ti Intersect] Materials buffer size: 1344bytes
[LuxRays][27.594] [Device GeForce GTX 1070 Ti Intersect] Material evaluation ops buffer size: 504bytes
[LuxRays][27.594] [Device GeForce GTX 1070 Ti Intersect] Material evaluation stacks buffer size: 3072Kbytes
[LuxRays][27.594] [Device GeForce GTX 1070 Ti Intersect] Scene objects buffer size: 168bytes
[LuxRays][27.610] [Device GeForce GTX 1070 Ti Intersect] Lights buffer size: 1660bytes
[LuxRays][27.610] [Device GeForce GTX 1070 Ti Intersect] Env. light indices buffer size: 4bytes
[LuxRays][27.610] [Device GeForce GTX 1070 Ti Intersect] Light offsets (Part I) buffer size: 28bytes
[LuxRays][27.610] [Device GeForce GTX 1070 Ti Intersect] Light offsets (Part II) buffer size: 16bytes
[LuxRays][27.610] [Device GeForce GTX 1070 Ti Intersect] Env. light distributions buffer size: 262208Kbytes
[LuxRays][27.688] [Device GeForce GTX 1070 Ti Intersect] LightsDistribution buffer size: 48bytes
[LuxRays][27.688] [Device GeForce GTX 1070 Ti Intersect] InfiniteLightSourcesDistribution buffer size: 48bytes
[LuxRays][27.688] [Device GeForce GTX 1070 Ti Intersect] Ray buffer size: 4608Kbytes
[LuxRays][27.703] [Device GeForce GTX 1070 Ti Intersect] RayHit buffer size: 1920Kbytes
[LuxRays][27.703] [Device GeForce GTX 1070 Ti Intersect] GPUTaskConfiguration buffer size: 272bytes
[LuxRays][27.703] [Device GeForce GTX 1070 Ti Intersect] GPUTask buffer size: 63744Kbytes
[LuxRays][27.703] [Device GeForce GTX 1070 Ti Intersect] GPUTaskDirectLight buffer size: 5760Kbytes
[LuxRays][27.703] [Device GeForce GTX 1070 Ti Intersect] GPUTaskState buffer size: 37632Kbytes
[LuxRays][27.703] [Device GeForce GTX 1070 Ti Intersect] GPUTask Stats buffer size: 384Kbytes
[LuxRays][27.703] [Device GeForce GTX 1070 Ti Intersect] SamplerSharedData buffer size: 32bytes
[LuxCore][27.703] [PathOCLBaseRenderThread::0] Size of a Sample: 16bytes
[LuxRays][27.703] [Device GeForce GTX 1070 Ti Intersect] Sample buffer size: 1536Kbytes
[LuxCore][27.703] [PathOCLBaseRenderThread::0] Size of a SampleData: 8bytes
[LuxRays][27.703] [Device GeForce GTX 1070 Ti Intersect] SampleData buffer size: 768Kbytes
[LuxCore][27.703] [PathOCLBaseRenderThread::0] Size of a SampleResult: 304bytes
[LuxRays][27.703] [Device GeForce GTX 1070 Ti Intersect] Sample buffer size: 29184Kbytes
[LuxRays][27.703] [Device GeForce GTX 1070 Ti Intersect] PathInfo buffer size: 10368Kbytes
[LuxRays][27.703] [Device GeForce GTX 1070 Ti Intersect] DirectLightVolumeInfo buffer size: 4224Kbytes
[LuxRays][27.703] [Device GeForce GTX 1070 Ti Intersect] Pixel Filter Distribution buffer size: 33Kbytes
[LuxCore][27.703] [PathOCLBaseRenderThread::0] Defined symbols:  -D LUXRAYS_OPENCL_KERNEL -D SLG_OPENCL_KERNEL -D RENDER_ENGINE_RTPATHOCL -D PARAM_RAY_EPSILON_MIN=1.000000e-05f -D PARAM_RAY_EPSILON_MAX=1.000000e-01f -D PARAM_USE_PIXEL_ATOMICS -D LUXCORE_NVIDIA_OPENCL
[LuxCore][27.703] [PathOCLBaseRenderThread::0] Compiling kernels
[LuxCore][141.219] [PathOCLBaseRenderThread::0] Kernels not cached
[LuxCore][141.219] [PathOCLBaseRenderThread::0] Compiling Film_Clear Kernel
[LuxCore][141.219] [PathOCLBaseRenderThread::0] Compiling InitSeed Kernel
[LuxCore][141.219] [PathOCLBaseRenderThread::0] Compiling Init Kernel
[LuxCore][141.219] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_RT_NEXT_VERTEX Kernel
[LuxCore][141.219] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_HIT_NOTHING Kernel
[LuxCore][141.219] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_HIT_OBJECT Kernel
[LuxCore][141.219] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_RT_DL Kernel
[LuxCore][141.219] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_DL_ILLUMINATE Kernel
[LuxCore][141.219] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_DL_SAMPLE_BSDF Kernel
[LuxCore][141.219] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_GENERATE_NEXT_VERTEX_RAY Kernel
[LuxCore][141.219] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_SPLAT_SAMPLE Kernel
[LuxCore][141.219] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_NEXT_SAMPLE Kernel
[LuxCore][141.219] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_GENERATE_CAMERA_RAY Kernel
[LuxCore][141.219] [PathOCLBaseRenderThread::0] AdvancePaths_MK_* workgroup size: 32
[LuxCore][141.219] [PathOCLBaseRenderThread::0] Kernels compilation time: 113515ms
[LuxCore][141.219] Starting 0 native render threads
get_changes(): checking for config changes took 0.0 ms
get_changes(): checking for camera changes took 0.0 ms
view_draw(): checking for changes took 1.0 ms
view_draw(): session.WaitNewFrame() took 226.0 ms
view_draw(): session.UpdateStats() took 0.0 ms
[LuxCore][141.453] Film OpenCL image pipeline
[LuxCore][141.453] Film OpenCL Device used: GeForce GTX 1070 Ti Intersect
[LuxCore][141.453]   Device OpenCL version: OpenCL 1.2 CUDA
[LuxRays][141.516] [Device GeForce GTX 1070 Ti Intersect] IMAGEPIPELINE buffer size: 4360Kbytes
[LuxRays][141.516] [Device GeForce GTX 1070 Ti Intersect] Merge buffer size: 5814Kbytes
[LuxCore][141.516] [MergeSampleBuffersOCL] Compiling Film_MergeBufferInitialize Kernel
[LuxCore][141.516] [MergeSampleBuffersOCL] Compiling Film_MergeRADIANCE_PER_PIXEL_NORMALIZED Kernel
[LuxCore][141.516] [MergeSampleBuffersOCL] Compiling Film_MergeRADIANCE_PER_SCREEN_NORMALIZED Kernel
[LuxCore][141.516] [MergeSampleBuffersOCL] Compiling Film_MergeBufferFinalize Kernel
[LuxCore][141.516] [MergeSampleBuffersOCL] Kernels compilation time: 0ms
[LuxRays][141.532] [LinearToneMap] Defined symbols:
[LuxRays][141.532] [LinearToneMap] Compiling kernels
[LuxRays][141.532] [LinearToneMap] Program cached
[LuxCore][141.532] [AutoLinearToneMap] Compiling LinearToneMap_Apply Kernel
[LuxCore][141.532] [LinearToneMap] Kernels compilation time: 0ms
view_draw(): framebuffer update took 69.0 ms
view_draw(): framebuffer drawing took 0.0 ms
view_draw(): showing stats in UI took 0.0 ms
view_draw() took 297.0 ms
get_changes(): checking for config changes took 1.0 ms
view_draw(): checking for changes took 2.0 ms
view_draw(): session.WaitNewFrame() took 1.0 ms
view_draw(): framebuffer update took 23.0 ms
view_draw() took 28.0 ms
I've deleted the next lines to stay in the allowed character
PS: when I try to unistall the LuxCore 2.3 addon I get this errror:
I've deleted the files in the folder with Blender closed.
addon_utils.disable: BlendLuxCore not disabled
  File "C:\Program Files\Blender Foundation\Blender 2.82\2.82\scripts\startup\bl_operators\userpref.py", line 773, in execute
    shutil.rmtree(path)
  File "C:\Program Files\Blender Foundation\Blender 2.82\2.82\python\lib\shutil.py", line 516, in rmtree
    return _rmtree_unsafe(path, onerror)
  File "C:\Program Files\Blender Foundation\Blender 2.82\2.82\python\lib\shutil.py", line 395, in _rmtree_unsafe
    _rmtree_unsafe(fullname, onerror)
  File "C:\Program Files\Blender Foundation\Blender 2.82\2.82\python\lib\shutil.py", line 400, in _rmtree_unsafe
    onerror(os.unlink, fullname, sys.exc_info())
  File "C:\Program Files\Blender Foundation\Blender 2.82\2.82\python\lib\shutil.py", line 398, in _rmtree_unsafe
    os.unlink(fullname)
PermissionError: [WinError 5] Accesso negato: 'C:\\Users\\Umby\\AppData\\Roaming\\Blender Foundation\\Blender\\2.82\\scripts\\addons\\BlendLuxCore\\bin\\embree3.dll'
Error: Traceback (most recent call last):
    shutil.rmtree(path)
    os.unlink(fullname)
