Linux Compiling LuxCore
Re: Linux Compiling LuxCore
I did manual numpy build as shared lib and renamed it to static lib without the 37 end,
got everything compiled, maybe.
Windows has this extra 2, OpenImageIO.dll pyluxcore.pyd
Are they not needed for Linux?
I have the libOpenImageIOBase.a and few smaller files.
How do i run the luxcore tools?
It's small file, not sure how to run the network node.
The entire LuxCore-opencl.tar.bz2 is only 70 MB, same like Azure auto build.
The cornell.scn is missing too
Unable to parse PLY file './Khaki.ply'
Run "python3 pyluxcoretools.zip help" and it will print an help: just run "python3 pyluxcoretools.zip netnode" for a network node.
Dade wrote: Fri Feb 14, 2020 2:56 pm Run "python3 pyluxcoretools.zip help" and it will print an help: just run "python3 pyluxcoretools.zip netnode" for a network node.
human@human:~/Documents/LuxCore-opencl$ python3 pyluxcoretools.zip help
  File "/usr/lib/python3.7/runpy.py", line 193, in _run_module_as_main
    "__main__", mod_spec)
  File "/usr/lib/python3.7/runpy.py", line 85, in _run_code
    exec(code, run_globals)
  File "pyluxcoretools.zip/__main__.py", line 40, in <module>
  File "pyluxcoretools.zip/pyluxcoretools/pyluxcoreconsole/cmd.py", line 26, in <module>
    The `default' method may be overridden to intercept commands for which there
ImportError: libboost_numpy37.so.1.67.0: cannot open shared object file: No such file or directoryCode: Select all
relocation R_X86_64_PC32 against symbol `BOOST_NUMPY_ARRAY_API'
Recompile with -fPICl disabled or somethingRe: Linux Compiling LuxCore
Error output with static libboost_numpy.a + shared libboost_numpy37.so.1.67.0 both together in lib folder.
[ 98%] Built target luxcoreui
[ 99%] Linking CXX shared module ../../lib/pyluxcore.so
/usr/bin/ld: /home/human/LinuxCompile/target-64-sse2/lib/libboost_numpy.a(dtype.o): relocation R_X86_64_PC32 against symbol `BOOST_NUMPY_ARRAY_API' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: final link failed: bad value
collect2: error: ld returned 1 exit status
make[2]: *** [src/luxcore/CMakeFiles/pyluxcore.dir/build.make:229: lib/pyluxcore.so] Error 1
make[1]: *** [CMakeFiles/Makefile2:579: src/luxcore/CMakeFiles/pyluxcore.dir/all] Error 2
make: *** [Makefile:84: all] Error 2
 !!! luxrays luxcore pyluxcore luxcoreui compilation failed
human@human:~/LinuxCompile$
I changed the build script little, for boost.
For python i have:
Now boost builds the python and numpy libs with no errors. Build goes from stage 1 to 5 with no issues.
Python3 console part works, but ui not. I get PySide2 errors with QT.
	if ! ./bootstrap.sh --with-toolset=$TOOLSET --without-icu --prefix=$TARGET/boost \
	--with-python-version=3.7 ; then
		echo " * Miauuuuuuuu"
		exit 1
	fi
	sleep $PAUSE
	if ./b2.......................Code: Select all
PYTHON_LIB=/usr/lib/python3.7/config-3.7m-x86_64-linux-gnu/libpython3.7m.a
PYTHON_INCLUDE=/usr/include/python3.7m/Python3 console part works, but ui not. I get PySide2 errors with QT.
human@human:~$ cd /home/human/Documents/LuxCore-opencl/
usage: pyluxcoretools.zip [commandToExecute]
PyLuxCoreTool
positional arguments:
  commandToExecute  help, console, merge, netconsole, netconsoleui, netnode or
                    netnodeui
human@human:~/Documents/LuxCore-opencl$ python3 pyluxcoretools.zip netconsole
[MainThread][2020-02-15 02:01:56,096] LuxCore 2.3beta1
usage: pyluxcoretools.zip [-s SECS] [-f SECS] [-n IPADDRESS [IPADDRESS ...]]
                          [-d] [-h]
PyLuxCoreNetConsole
optional arguments:
  -s SECS, --stats-period SECS
                        node statistics print period
  -f SECS, --film-period SECS
                        node film update period
  -n IPADDRESS [IPADDRESS ...], --nodes IPADDRESS [IPADDRESS ...]
                        rendering nodes ip addresses
  -d, --disable-auto-discover
                        disable node auto-discover
  -h, --help            Show this help message and exit
usage: pyluxcoretools.zip [-p SAMPLES_PER_PIXEL] [-t SECS]
                          fileToRender
Render configuration options
  fileToRender          .bcf file to render
optional arguments:
  -p SAMPLES_PER_PIXEL, --halt-spp SAMPLES_PER_PIXEL
                        samples/pixel halt condition
  -t SECS, --halt-time SECS
                        time halt condition
human@human:~/Documents/LuxCore-opencl$ python3 pyluxcoretools.zip netconsoleui
FIXME Subscripted generics cannot be used with class and instance checks
  File "pyluxcoretools.zip/__main__.py", line 66, in <module>
  File "pyluxcoretools.zip/pyluxcoretools/pyluxcorenetconsole/ui.py", line 462, in main
  File "pyluxcoretools.zip/pyluxcoretools/pyluxcorenetconsole/ui.py", line 453, in ui
  File "pyluxcoretools.zip/pyluxcoretools/pyluxcorenetconsole/ui.py", line 172, in __init__
  File "pyluxcoretools.zip/pyluxcoretools/pyluxcorenetconsole/mainwindow.py", line 17, in setupUi
TypeError: 'PySide2.QtWidgets.QWidget' called with wrong argument types:
  PySide2.QtWidgets.QWidget(MainApp)
Supported signatures:
  PySide2.QtWidgets.QWidget(typing.Union[PySide2.QtWidgets.QWidget, NoneType] = None, PySide2.QtCore.Qt.WindowFlags = Default(Qt.WindowFlags))
It looks like a problem in the PySide2 version you have installed: you may need something older or newer, it depends on what you have installed.Fox wrote: Sat Feb 15, 2020 12:04 am Python3 console part works, but ui not. I get PySide2 errors with QT.
It's the latest pyside2 5.14.1Dade wrote: Sat Feb 15, 2020 12:33 pm It looks like a problem in the PySide2 version you have installed: you may need something older or newer, it depends on what you have installed.
I will check the older versions.
I went to the pyside2 version that worked in Windows (5.12.3).
Still same error:
TypeError: 'PySide2.QtWidgets.QWidget' called with wrong argument types: PySide2.QtWidgets.QWidget(MainApp)
						Still same error:
