Linux Compiling LuxCore
Re: Linux Compiling LuxCore
I did manual numpy build as shared lib and renamed it to static lib without the 37 end,
got everything compiled, maybe.
Windows has this extra 2, OpenImageIO.dll pyluxcore.pyd
Are they not needed for Linux?
I have the libOpenImageIOBase.a and few smaller files.
How do i run the luxcore tools?
Run "python3 pyluxcoretools.zip help" and it will print an help: just run "python3 pyluxcoretools.zip netnode" for a network node.
human@human:~/Documents/LuxCore-opencl$ python3 pyluxcoretools.zip help
File "/usr/lib/python3.7/runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "/usr/lib/python3.7/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "pyluxcoretools.zip/__main__.py", line 40, in <module>
File "pyluxcoretools.zip/pyluxcoretools/pyluxcoreconsole/cmd.py", line 26, in <module>
The `default' method may be overridden to intercept commands for which there
ImportError: libboost_numpy37.so.1.67.0: cannot open shared object file: No such file or directory
relocation R_X86_64_PC32 against symbol `BOOST_NUMPY_ARRAY_API'
Recompile with -fPICl disabled or something
Error output with static libboost_numpy.a + shared libboost_numpy37.so.1.67.0 both together in lib folder.
[ 98%] Built target luxcoreui
[ 99%] Linking CXX shared module ../../lib/pyluxcore.so
/usr/bin/ld: /home/human/LinuxCompile/target-64-sse2/lib/libboost_numpy.a(dtype.o): relocation R_X86_64_PC32 against symbol `BOOST_NUMPY_ARRAY_API' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: final link failed: bad value
collect2: error: ld returned 1 exit status
make[2]: *** [src/luxcore/CMakeFiles/pyluxcore.dir/build.make:229: lib/pyluxcore.so] Error 1
make[1]: *** [CMakeFiles/Makefile2:579: src/luxcore/CMakeFiles/pyluxcore.dir/all] Error 2
make: *** [Makefile:84: all] Error 2
!!! luxrays luxcore pyluxcore luxcoreui compilation failed
human@human:~/LinuxCompile$
I changed the build script little, for boost.
For python i have:
Now boost builds the python and numpy libs with no errors. Build goes from stage 1 to 5 with no issues.
Python3 console part works, but ui not. I get PySide2 errors with QT.
if ! ./bootstrap.sh --with-toolset=$TOOLSET --without-icu --prefix=$TARGET/boost \
--with-python-version=3.7 ; then
echo " * Miauuuuuuuu"
exit 1
fi
sleep $PAUSE
if ./b2.......................
PYTHON_LIB=/usr/lib/python3.7/config-3.7m-x86_64-linux-gnu/libpython3.7m.a
PYTHON_INCLUDE=/usr/include/python3.7m/
human@human:~$ cd /home/human/Documents/LuxCore-opencl/
usage: pyluxcoretools.zip [commandToExecute]
PyLuxCoreTool
positional arguments:
commandToExecute help, console, merge, netconsole, netconsoleui, netnode or
netnodeui
human@human:~/Documents/LuxCore-opencl$ python3 pyluxcoretools.zip netconsole
[MainThread][2020-02-15 02:01:56,096] LuxCore 2.3beta1
usage: pyluxcoretools.zip [-s SECS] [-f SECS] [-n IPADDRESS [IPADDRESS ...]]
[-d] [-h]
PyLuxCoreNetConsole
optional arguments:
-s SECS, --stats-period SECS
node statistics print period
-f SECS, --film-period SECS
node film update period
-n IPADDRESS [IPADDRESS ...], --nodes IPADDRESS [IPADDRESS ...]
rendering nodes ip addresses
-d, --disable-auto-discover
disable node auto-discover
-h, --help Show this help message and exit
usage: pyluxcoretools.zip [-p SAMPLES_PER_PIXEL] [-t SECS]
fileToRender
Render configuration options
fileToRender .bcf file to render
optional arguments:
-p SAMPLES_PER_PIXEL, --halt-spp SAMPLES_PER_PIXEL
samples/pixel halt condition
-t SECS, --halt-time SECS
time halt condition
human@human:~/Documents/LuxCore-opencl$ python3 pyluxcoretools.zip netconsoleui
FIXME Subscripted generics cannot be used with class and instance checks
File "pyluxcoretools.zip/__main__.py", line 66, in <module>
File "pyluxcoretools.zip/pyluxcoretools/pyluxcorenetconsole/ui.py", line 462, in main
File "pyluxcoretools.zip/pyluxcoretools/pyluxcorenetconsole/ui.py", line 453, in ui
File "pyluxcoretools.zip/pyluxcoretools/pyluxcorenetconsole/ui.py", line 172, in __init__
File "pyluxcoretools.zip/pyluxcoretools/pyluxcorenetconsole/mainwindow.py", line 17, in setupUi
TypeError: 'PySide2.QtWidgets.QWidget' called with wrong argument types:
PySide2.QtWidgets.QWidget(MainApp)
Supported signatures:
PySide2.QtWidgets.QWidget(typing.Union[PySide2.QtWidgets.QWidget, NoneType] = None, PySide2.QtCore.Qt.WindowFlags = Default(Qt.WindowFlags))
It looks like a problem in the PySide2 version you have installed: you may need something older or newer, it depends on what you have installed.
I went to the pyside2 version that worked in Windows (5.12.3).
Still same error:
TypeError: 'PySide2.QtWidgets.QWidget' called with wrong argument types: PySide2.QtWidgets.QWidget(MainApp)
Still same error:
