HOWTO - compile on OSX 2020
Ahr0n
Re: HOWTO - compile on OSX 2020
Post by Ahr0n »
Thank you. Almost done but there is one issue with the last step. I am in LuxCore folder, I do chmod +x pack_lux_osx.sh and then ./pack_lux_osx.sh but this happens:
./pack_lux_osx.sh: line 1: {rtf1ansiansicpg1250cocoartf1671cocoasubrtf600: command not found
./pack_lux_osx.sh: line 2: syntax error near unexpected token `}'
./pack_lux_osx.sh: line 2: `{\fonttbl\f0\fnil\fcharset0 Monaco;}'
So this is the last step but I had one issue after changing the AZURE to 0. I mean this step:
export PATH="/usr/local/opt/bison/bin:/usr/local/bin:$PATH"
DEPS_SOURCE=`pwd`/macos
mkdir build
cd  build
cmake -DOSX_DEPENDENCY_ROOT=$DEPS_SOURCE -DCMAKE_BUILD_TYPE=Release ..
make
Everything's okay but the last command - make doesn't make anything and I get an info:
imac-marcin:build Martin$ make
make: *** No targets specified and no makefile found.  Stop.
So two questions: How can I solve first and second issue?
u3dreal
Post by u3dreal »
Ahr0n wrote: Fri Jan 31, 2020 3:39 pm Thank you. Almost done but there is one issue with the last step. I am in LuxCore folder, I do chmod +x pack_lux_osx.sh and then ./pack_lux_osx.sh but this happens:
mkdir build
cd  build
make
1. looks like you copied too much here ... just the green text ....it should start with "#!/bin/bash"
2. you did something wrong there is nothing to make in the "build" dir so i guess you forgot the ".." with the cmake command
portfolio http://q3de.com/
Fox
Post by Fox »
If Mac tutor is done, then Linux next plz :)
u3dreal
Post by u3dreal »
Fox wrote: Sat Feb 01, 2020 4:24 pm If Mac tutor is done, then Linux next plz :)
https://wiki.luxcorerender.org/Compiling_LuxCore
Have a look here
Fox
Post by Fox »
u3dreal wrote: Sat Feb 01, 2020 11:27 pm
Have a look here
When i run ./build-64-sse2 it gets stuck at finding python and opencl :roll:
u3dreal
Post by u3dreal »
plz open a new thread ... this is OSX
Fox
Post by Fox »
u3dreal wrote: Sun Feb 02, 2020 12:06 am plz open a new thread ... this is OSX
Sure. I will do it later, i have long border render going and can't log off windows right now to play with Linux. Maybe week or so.
A friend of mine is trying to install the lastest blendluxcore for Mac but it is craching evrytime at installation :
This build : https://github.com/LuxCoreRender/BlendL ... _v2.3beta1
Sys / Mac Pro 2013 and os 10.14.6 both blender 2.81 and 2.82 craShing on install.
When he try to enable addon after installation it crash. Blender close itself when you try to enable the addon.
u3dreal
Post by u3dreal »
Yes will have to invest a little more i guess.
Have not been able to reproduce the problem on Mojave :|
u3dreal
Post by u3dreal »
This updated guide can now be found here
