juangea
Post by juangea »
I've been testing the latest build and I encountered a bug, since you've been touching things related to UV's and OpenCL I wonder if this bug with the Bricks map is related, because it happens with openCL and it mentions TextureMapping3D, if it's not I will create another thread about it:
PathOCLBase kernel compilation error:
ERROR clBuildProgram[CL_BUILD_PROGRAM_FAILURE]:
<kernel>:9040:57: error: too few arguments to function call, expected 3, have 2
        const float3 P = TextureMapping3D_Map(mapping, hitPoint);
<kernel>:4936:1: note: 'TextureMapping3D_Map' declared here
OPENCL_FORCE_NOT_INLINE float3 TextureMapping3D_Map(global const TextureMapping3D *mapping,
<kernel>:1:33: note: expanded from macro 'OPENCL_FORCE_NOT_INLINE'
#define OPENCL_FORCE_NOT_INLINE attribute__((noinline))
I should have already fixed that bug, you just need binaries from the very last sources.
juangea
Post by juangea »
ok, then I imagine tomorrow there will be a new daily build, we are using the one from github from 5 hours ago :)
Post by lacilaci »
Dade wrote: Wed Jan 08, 2020 12:00 am I should have already fixed that bug, you just need binaries from the very last sources.
So the daily build on github either isn't up to date, or the problem(s) still exists.
here's no uv on OCL:
and here on cpu:
notice that both objects show a faint seam on top but opencl version is also weirdly stretched (object is parented to empty and animated)
here's object with UV on opencl:
and here with uv and on cpu
having UV's fix the faint seam on both renders now but opencl still stretches the map weirdly. So right now only rendering on cpu while also having uvs work 100%.
here's the testscene:
test.rar
(3.35 MiB) Downloaded 280 times
I tested daily build from github, downloaded this morning. I also wanted to check build from azure but it says build not found.
acasta69
Post by acasta69 »
lacilaci wrote: Wed Jan 08, 2020 6:33 am So the daily build on github either isn't up to date, or the problem(s) still exists.
Apparently the build has been uploaded fine, at least the timestamps of the binaries seem correct.
juangea
Post by juangea »
Awesome, we’ll try it in less than an hour :)
Thanks!
EDIT: the build has 14 hours, so theoretically is the same we were using, we are going to re-update it just in case something went wrong with our previous update.
I’ll tell you how it goes and if it works correctly, thanks :)
I should have now fixed this problem too: it was related to using a transformation in triplanar node (it was already working fine without transformation like in my test).
Post by lacilaci »
Dade wrote: Wed Jan 08, 2020 10:37 am
hm. and if you compare my tests cpu with uv VS cpu without uv... is that also affected by transformation? Cause I understand the stretching but there is clearly a difference even on cpu (uv-no uv)
Post by lacilaci »
Aaand I even ran into an opposite problem.
object that has some uv(although bad one)
object has no uv(deleted uv's)
this is another pretty bad issue cause what If I want to use UV's for diffuse texture, but my roughness texture I want to have use triplanar.
How can I make sure my triplanar isn't affected by uv's or it's quality.
juangea
Post by juangea »
We just updated the build and the bug I told you is not present anymore :)
