Happy new year everyone
I want to know if its possible to blur or make the transition from shadow to lit area (i guess its called the shadow terminator ? ) more smooth, without changing anything in the scene(e.g. lights) except the shader.
I know that luxcore has diffuse roughness, but that produces not the desired effect.
On this forum i found a couple of example comparisons by the user (Fluss) :
https://corona-renderer.com/forum/index ... #msg120362
Every renderer there behaves the same, which is probably physically correct, but the look i am after can be found in this image :
https://corona-renderer.com/forum/index ... 9194;image
The top half has a harsh line between shadow and lit area (meh), the bottom half has this nice soft falloff (great).
On another forum i have found a user (kosso_olli), who made a comparison between vrayrt and fstorm:
Fstorm
https://forums.chaosgroup.com/filedata/ ... 1471338786
VrayRT:
https://forums.chaosgroup.com/filedata/ ... 1471338796
Due to the nice soft falloff the fstorm image gains alot of depth, see the cushion part at the bedhead or the pillow in front.
In constrast the vray rendering looks pretty flat.
My guess is that this behaviour isn't physically correct, but is it possible to emulate it with some clever shader node setup or normal map trickery ?
Does somebody have any hints or ideas regarding this ?
Thanks in advance
Fade out / smooth shadow terminator ?
Re: Fade out / smooth shadow terminator ?
It is really more a light source problem than a material one. You get this kind of rendering when using a point light source:
It is a quite "unnatural" type of light source and, shadow terminator problem aside, it doesn't look realistic. Just use radius > 0.0 and it will start to look a lot better:
Thank you Dade for the fast reply,
but I guess i haven't expressed myself well, i know how to achieve that look with a point light, that's how i made the example in my first post.
The sphere was also just an example, in an actual scene you have alot of different light sources, but i want that look on every surface regardless of the light source. Like in the bedroom scene images, which uses a hdri.
Fstorm ( with smooth falloff, creates a nice depth )
VrayRT: ( without smooth falloff, in comparison to fstorm looks flat )
Since i can't change the lights, nor the geometry i can only make adjustments to the shaders to get the desired effect.
But i guess a user cannot change the shadow terminator with a simple "normal map" trickery or other means?
I understand the problem but don't think there is currently a way to work around without writing some additional code. RoughMatte material is somewhat intended to address your problem but it is useless if you use something like a point light (the sharp transition between light and shadow will be still there because it is something coming from the light source, not the material).
Your request is also "qualitative" and a bit subjective (i.e. the VrayRT output looks better than Fstorm one to me). I have the feeling that your problem may be solved with some image post processing May be adjusting the color ramp
i've the same feeling.our request is also "qualitative" and a bit subjective (i.e. the VrayRT output looks better than Fstorm one to me).
Yes, the flat look on the vray comparison renders is definitely easily fixable in post.Dade wrote: ↑Thu Jan 02, 2020 11:39 pm I understand the problem but don't think there is currently a way to work around without writing some additional code. RoughMatte material is somewhat intended to address your problem but it is useless if you use something like a point light (the sharp transition between light and shadow will be still there because it is something coming from the light source, not the material).
However!
Fstorm is the best when it comes to postproces, and I think that even if you disable tonemapping/postprocesing in vfb, fstorm still does some sort of tonemapping and stuff anyways. It's like magic, tonemapping and "color science" you can get straight in fstorm framebuffer is just miles ahead of everybody else. And I think that's what's happening in the comparison, fstorm does some adjustments with tonemapping rather shading itsels.
Maybe I'm worng though, i'm no specialist on the matter...
Anyway, I hope some day a dev. joines luxcore and reproduces something like fstorm's postprocessing so that we don't have to deal with blender's terrible ideas of tonemapping or, someone fixes blender's color insanity. Right now the best you can do is get a flat looking output and "fix" it in post.
