lacilaci
Post by lacilaci » Wed Dec 25, 2019 11:48 am
Any news on these 2 features? I know triplanar was in the works but not sure if some progress was made lately...
alpistinho
Post by alpistinho » Thu Dec 26, 2019 2:31 pm
Sorry, I have been super busy lately and couldn't work on that.
I was hoping to have it done by the end of the year, but I have to merge the Multi UV changes into my triplanar branch.
I'll make an effort to have this done soon
lacilaci
Post by lacilaci » Tue Dec 31, 2019 5:57 am
Great, I got it working... Will test it out in upcoming days.
Do you think that it could also have control over blend factor? Like how tight is the blend area similar to how cycles has control with it's box mapping blending in image texture node?
lacilaci
Post by lacilaci » Tue Dec 31, 2019 6:20 am
I'm kinda confused. It still asks for UV map when I use the node... The object needs uv's when using triplanar?
Post by Dade » Wed Jan 01, 2020 10:50 am
Do you mean it needs a mesh with UV coordinates or the texture node has still a mapping option ?
The node mapping type triggers different behaviors: https://github.com/LuxCoreRender/LuxCor ... ar.cpp#L47
GLOBALMAPPING3D and LOCALMAPPING3D works are you expected (i.e. the node mapping is not used).
UVMAPPING3D use the node mapping to transform the point coordinates in UV coordinates.
Post by Dade » Wed Jan 01, 2020 11:01 am
But the BlendLuxCore pull request (https://github.com/LuxCoreRender/BlendLuxCore/pull/320) hasn't yet been merged ... what version are you using ?
lacilaci
Post by lacilaci » Wed Jan 01, 2020 11:07 am
When i've put texture in the triplanar node inputs it didn't do anything and when i made some basic uvs for the mesh, texture showed up on object but it was weirdly stretched and had different density on different parts of the mesh.
I'll try to play around with it llater today or sometime tomorrow on few other objects.
I know it wasnt merged, I just created files and copied the code etc manualy. (that actually might be the problem, lol)
Post by Dade » Wed Jan 01, 2020 11:13 am
You probably need to set the 3 textures to use LOCALMAPPING3D and have the center of the mesh object well placed to have the expected behavior.
lacilaci
Post by lacilaci » Thu Jan 02, 2020 5:48 am
ok, a simple sphere.
the one on the right has uv mapping (wih seam accross the center which you can clearly see) the one on the left has no uv mapping
1. it's pretty clear that if an object has uv mapping the triplanar mapping is somehow using it as it's different as with an object that has no uv's
2. if object has no uv's the mapping is stretched weirdly
3. 2d texture node in blender doesn't even allow to input 3d mapping
So, maybe I'm doing something wrong, maybe I broke something while "hacking" this thing into blendluxcore from pull request or maybe it's not working properly...? Can someone esle test a basic sphere(or other object) without UV's and using a texture?
EDIT:
Actualy it's a bit different, cause the sphere has some uv mapping already, if I delete the uv's I get no texture projection on the object
Post by Dade » Thu Jan 02, 2020 11:45 pm
I have the feeling the BlendLuxCore support is wrong, you have to set the mapping of the triplaner texture node to LOCALMAPPING3D ... but it looks like you don't have a mapping setting there.
I will try to check.
P.S. it is than very important to have the object local reference origin at the center of the sphere.
