Oddly when using the pattern when rendering looks horizontally stretched and when turning on denoise
openCl noise
CPU noise
Win10
MacPro 2012 Xeon
2x GTX 1070 Ti
CPU Rendering
openCL Rendering
Any idea what can cause this? I observed similar with Lux in Blender 2.8 on the macOS side.
							Noise artifact with openCL
Re: Noise artifact with openCL
Hi and welcome to the forum,
the horizontal noise patterns are an artifact of OpenCL Sobol sampling on the GPU.
OIDN is not trained for this and then gets creative with it
To avoid that just use the random sampler (Render properties/light paths/advanced/Sampler).
@epilectrolytics
Thank you for the tip! Everything works fine now!
It is a known property of our OpenCL Sobol sampler. The stripes will vanish once more samples are rendered. Only switch to the random sampler if you really need to stop the rendering with such a high amount of noise for some reason.
