Updated principled shader
Post by lacilaci »
Any word on the addet transmitance features for disney?
Even with latest shadow tricks, proper volume for liquids on glass gets super dark unless liquid is "architectural"(and even then it's affected by glass, see attached images). Some cheap sss in disney could be useful for these (and for skin, etc..)
here:
shadows are disabled (set to white, in both) yet volume always struggles to get some proper lighting. I assume this is correct behaviour and I simply need fake/simple sss as in cycles or wait forever and use caustics maybe...?
Re: Updated principled shader
Post by lacilaci »
Volume on it's own kinda works, but it has to have null as material (so just volume is used)
The moment any glass is introduced it goes dark...
Fox
Post by Fox »
With rough glass it's not dark, but you still need GPU or 2.
Here 10 min on older cpu, this should be 1 min on gpu.
HybridBackForwardPhotonGi
2.81a Blend
juice2_Fox.7z
(1.81 MiB) Downloaded 1720 times
Post by lacilaci »
Fox wrote: Thu Dec 26, 2019 2:59 am With rough glass it's not dark, but you still need GPU or 2.
2.81a Blend
juice2_Fox.7z
hm.. rough glass kinda helps if I disable glass shadows completely... but without any shadow at all it kinda looks weird in scene
Post by lacilaci »
Aaand no, not good enough...
I really hope that principled shader sss will make this doable
lacilaci wrote: Thu Dec 26, 2019 8:41 am Aaand no, not good enough...
Wonder how renderer like Octane and cycles results look like in this specific case ?
Post by lacilaci »
Sharlybg wrote: Thu Dec 26, 2019 8:43 am
Well it's difficult to produce good looking juice in general, this is why some added flexibility is needed.
First, some basic sss materials should be very easy to set up (how disney allows or what corona does) and then as more rough it gets, or more scattering is happening it should be compensating somehow for the darkening.
For example even rough glass gets very dark the more rough it gets, if you look at principled shader in cycles the use of multiscattered ggx will always keep the glass bright. Maybe something similar is happening with volumes in luxcore cause the more scattering the volume gets the darker it gets (maybe physically correct but looks unusable mostly)
Post by lacilaci »
I can kinda get it correct looking when making the juice smaller...
it only get's darker when juice mesh penetrates glass mesh
not touching glass
filled glass(with a bit of juice mesh going into glass)
maybe this could be fixed?
for now, the only way that I can get correct looking volume in glass is making the liquid just a very little smaller than the inside.
This will of course break how refraction works on the glass edges. There has to be a way to fix it when it's inside glass mesh (volume priorities don't do anything for this issue, I tried...)
I have set up a simple test scene with a slice of glass and an overlapping volume cube:
The glass has zero reflection, 100% transmission and 95% shadow transparency, it renders as expected:
Try to set up a scene like this one for checking how/if it works. Once you have the result you want, you can go back to the real world scenario.
Fox
Post by Fox »
There are some volume priority anomalies with non overlapping volumes.
When i use priority 0 for all,
or i use 0 for world and 3 for glass and 4 for juice,
then it looks like that:
But in case of 0 for world and 4 for glass and 3 for juice,
the outcome is different:
