Image pipeline for Luxcoreui
Racleborg
Post by Racleborg »
What Is the correct way to set up the image pipeline in Blender so that it matches Luxcoreui?
Thank you
marcatore
Re: Image pipeline for Luxcoreui
Post by marcatore »
Seems quite impossible...or at least not an easy task.
It's a pity cause also the network rendering is different from what you render with Blender.
I can't use network rendering due to this...it's a pity.
Racleborg
Post by Racleborg »
by marcatore » Thu Dec 05, 2019 10:12 am
Ok. I understand.
It will be terrific once baking Lux textures is available inside Blender. ( I have an animation going on at the moment that could take weeks to render ;) )
Thank you for your response.
marcatore wrote: Thu Dec 05, 2019 10:12 am Seems quite impossible...or at least not an easy task.
I'm missing something or you have the same result if you use just the default settings ?
I mean, if you open Blender and you render the cube-over-the-plane or if you export the scene and you render the cube-over-the-plane in luxcoreui, you get the same result, no ?
Racleborg
Post by Racleborg »
Earlier, I set the colour management to 'STANDARD' in Blender 2.81 and it now looks the same to me as in luxcore.
However, the nice thing about Filmic is its dynamic range prevents a lot of blow-out with bright lights. (or maybe, I'm not using the 'STANDARD' correctly).
marcatore
Post by marcatore »
Dade wrote: Thu Dec 05, 2019 10:51 am I'm missing something or you have the same result if you use just the default settings ?
If I'm not in trouble...I think that this is the same of this thread
viewtopic.php?f=4&t=1443
Or not?
marcatore wrote: Thu Dec 05, 2019 11:21 am If I'm not in trouble...I think that this is the same of this thread
Or not?
Yes but you had a modified Blender image pipeline there. What I'm saying is: if you use the default post-processing settings you should get the same output out of Blender, LuxCoreUI, Network rendering, etc. or not ?
alpistinho
Post by alpistinho »
As long as you don't use filmic, everything should match.
Can't you create an extra image pipeline to export the result in HDR (exr file format) and then post process it in Blender using filmic?
