And a BIG BIG thank you for your help!
So far, so good. I'll treasure this advices, and asap, i'll try those!
Thank you again
							Luxrender vs Cycles NOISE
Re: Luxrender vs Cycles NOISE
- do more with less -
Sharly, i understood all but this:
Not sure about thicked walls meaning.
Are u referring to faces with solidify modifier? to add thickness?
Or simply to have joined faces?
Thank you.
4__ always use thicked walls. will save you a lot headache.
Thank you.
Do not use a flat rectangle to model a wall but use a box (so the wall has some real thickness/depth like a real wall).c3kkos wrote: Thu Nov 21, 2019 3:51 pm Sharly, i understood all but this:
Not sure about thicked walls meaning.Code: Select all
