Sharp corners looking smooth
AndreKR
Post by AndreKR »
I attached a scene I made.
There are some sharp corners that look smooth in Lux:
The same area in Cycles:
This area also looks weird (there's also a shadow terminator issue here, but that's not what I mean):
Cycles:
What is going on?
lampe2.blend
(1.87 MiB) Downloaded 756 times
Racleborg
Re: Sharp corners looking smooth
Post by Racleborg »
Maybe Lux isn't seeing the MARK SHARPs :?:
BlendLuxCore supports Blender's auto smooth, but it does not support custom normals. I have not looked at the file yet, but maybe you are using custom normals?
Mark sharp works if used with autosmooth or the edge split modifier.
At the moment, you have to clear the custom split normal data to have a working mesh in Lux.
In a quick test it seems to fix the problem, however I don't know what this data was needed for exactly, so you will have to consider if this model works without the custom normals.
It is planned to implement this feature eventually.
AndreKR
Post by AndreKR »
Wow, thanks, I would have never found that myself.
I imported the mesh from an .obj that I made in MoI, so this "custom split normals data" is apparently something that comes from the .obj importer. Removing it seems to have no effect on the mesh.
AndreKR
Post by AndreKR »
Could LuxCoreRender maybe just ignore this data? Because it seems it has to be cleared manually for every object. :|
We are currently ignoring it, and this is the result we get.
So I fear the answer is no, Blender skrews with the mesh data in some way and ignoring doesn't help.
