Air Dust
Air Dust
Just why it doesn't work if the "Cube" volume object totally surround the camera ?
Working
not Working
blendfile
dust air.blend
(735.3 KiB) Downloaded 886 times
Egert_Kanep
Re: Air Dust
Post by Egert_Kanep »
Probably interior and exterior volume are not defined for objects. Attached fixed blend conf
dust air_edit.blend
(751.95 KiB) Downloaded 831 times
Re: Air Dust
Egert_Kanep wrote: Wed Oct 23, 2019 1:49 pm Probably interior and exterior volume are not defined for objects. Attached fixed blend conf
Thanks you for the help. So everything have to be correctly setup manually like you did.I can understand the logic behind.
So now why my initial method is working ? i don't know :roll:
What is the limitation if it is a bad method ? don't know .
Really thaks you for the help.
Re: Air Dust
Sharlybg wrote: Wed Oct 23, 2019 2:53 pm
You have to set the camera or world volume.
Re: Air Dust
Set as same as my cube volume or a new volume ("air") ? anyway i've done both and it doesn't work.
tried Both
Egert_Kanep
Re: Air Dust
Did you also define ext volume for your room object?
Re: Air Dust
Egert_Kanep wrote: Wed Oct 23, 2019 3:59 pm Did you also define ext volume for your room object?
No because that way it will be just replicating your working method. What i want to understand before Dade answer is why my first method work. ( No need to define room and camera volume. just put camera a bit outside of the volume).
Want to know why this one work.
Egert_Kanep
Re: Air Dust
I think because by default camera assumes air to be ext interior and you view into the fog, not inside it. I might be wrong tough.
Re: Air Dust
Sharlybg wrote: Wed Oct 23, 2019 4:03 pm
Given the fact that your a very experienced user, your question should weigh a lot more.
I guess there is an issue or at least an illogical behavior in the handling of volumes. Not only the camera omits scattering volume but also light sources depend on location, i.e. under some circumstances the beam is visible in the scattering volume if the light source is placed outside the volume but the beam is not visible if the light source is placed in the volume, e.g. laser. Strange enough, the beam gets visible after reflection by a mirror. (At least I observed these effects in LuxCoreRender V2.2.)
wasd
Re: Air Dust
Post by wasd »
Dade wrote: Wed Oct 23, 2019 3:17 pm
Camera volume does not work.
